Helicopter AcademyTigerTugsFrasca VRForum468VOLO_VRHome200
What requirements are there for hauling Jet-A by truck for helicopter support?
off site fueling ground crew jet-a fuel truck
  • Please log in to reply
10 replies to this topic
#1 Spirit of '69
Spirit of '69
    VR Veteran Poster
  • VR Member
  • PipPipPipPipPipPipPip
  • 62 posts
  • Gender:Male
  • Company working for:Up North Helicopters and Enstrom Helicopter Corp. Gold Seal CFI-CFII, IGI
Posted 28 April 2015 - 09:56
So, in the spirit of CYA, I'm wondering what rules should I go by to transport Jet-A in a 100g tank mounted on a truck on U.S. roads in support of a commercial helicopter operation? I called a guy wanting to sell me a trailer, and he said there were none for Jet-A, only 100ll. Although every support truck I've ever seen has markings of some kind, I'm simply having a difficult time finding any regs on the subject that aren't for Pt 139 certified aiports. Thanks in advance!
  • pillsoi likes this
#2 Flying Pig
Flying Pig
    VR Veteran Poster
  • VR Member
  • 1,931 posts
Posted 28 April 2015 - 10:02
Contact the DOT or Dept of Motor Vehicles for your state. That would be the way to know for sure.
  • Wally likes this
#3 rotormandan
rotormandan
    VR Veteran Poster
  • VR Member
  • 667 posts
Posted 28 April 2015 - 13:34
No issues untiil 119 gallons. Then it must be placarded, cdl needed with hazmat endorsement, and lots of other paperwork.
I believe 100ll would be the same.
Edited by rotormandan, 28 April 2015 - 13:35.
  • adam32 and Spirit of '69 like this
#4 adam32
adam32
    VR Veteran Poster
  • VR Member
  • 1,233 posts
  • Gender:Male
  • Company working for:Just keeping the bills paid!!
Posted 28 April 2015 - 16:57
Yup.
I hauled around a 100 gallon tank with 100LL in the bed of my truck for a couple years. Totally legal.
  • Spirit of '69 likes this
#5 Rotorhead84
Rotorhead84
    VR Veteran Poster
  • VR Member
  • 148 posts
  • Gender:Male
Posted 01 May 2015 - 21:03
As long as you don't exceed 119 gallons you're good to go.  Don't need to do anything.  And if you need more than 119 gallons, just use two tanks.  As long as each tank isn't over 119 gallons you don't need a hazmat or placards.
#6 rotormandan
rotormandan
    VR Veteran Poster
  • VR Member
  • 667 posts
Posted 01 May 2015 - 22:51
I believe there's some rule about multiple tanks not being part of the same system. Meaning you need a seperate pump for each. I don't know the rule exactly. I haven't delt with it.
Spirit: just for an easy quick check if the rules, go get a cdl study guide from the dmv. It's free and a short read. Read the hazmat section, tanker section, and the hazmat part in the general section. It'll be about the same in any state and won't be more then 30 pages with pictures. At least it'll give you an idea if a cdl is required.
#7 500F
500F
    VR Veteran Poster
  • VR Member
  • 203 posts
  • Gender:Male
Posted 06 May 2015 - 11:58
There are a ton of misconceptions about this, many of them expressed in this thread alone.
These are federal DOT Rules. No states have any rules that supersede to my knowledge.
Read 49CFR 172.101, Fuel aviation turbine and note exception 150. This exception explained 173.150 allows any fuel with a flashpoint over 100F (classified, or re-classified as combustible, the latter applies to Jet A) to be carried in non-bulk packages (119gallons or less) See 49 CFR 171.8
This exemption was designed for carriage of barrels or for diesel fuel tanks for the agricultural and utility industries that operate vehicles in remote areas. It allows Jet A or diesel to be carried in tanks under 119 gallons in unlimited quantity on trucks or trailers without any need for Plackarding, CDL, etc. It would NOT apply to 100LL or any Gasoline because the flashpoint is too low.
There is no rule about multiple tanks being part of the same system, though it could be possible for a DOT inspector to determine that the tank capacity is greater than 119 gal if the tanks are interconnected (valves open) going down the roadway. Realistically, if the truck rolls over with 20 barrels on board many are going to spill interconnected or not, same with the 119 tanks. As long your tanks meet the definition of 171.8 and a puncture to 1 tank cant drain more than 119 gallons, you are good.
I've been investigated, and cleared by the DOT for this very thing. It may cause you some headaches, but its legal if you do it right.
#8 Spirit of '69
Spirit of '69
    VR Veteran Poster
  • VR Member
  • 62 posts
  • Gender:Male
Posted 13 July 2015 - 17:15
Thanks 500F, that was the short and sweet version. I will go check out the CDL manual rotormandan, I have some bigger ideas I'm pondering... Trailering my 480B...
#9 ridethisbike
ridethisbike
    VR Veteran Poster
  • VR Member
  • 664 posts
  • Gender:Male
  • Interests:Motorcycles, helicopters (duh), and the great outdoors
Posted 18 July 2015 - 22:30
Sooo.... All of that can be pretty confusing.... In regards to 100LL, what is the regulation then? 66lbs? If I read it all correctly anyways, which I probably didn't...
#10 500F
500F
    VR Veteran Poster
  • VR Member
  • 203 posts
  • Gender:Male
Posted 29 July 2015 - 12:13
Basically. There is a minimal quantities exemption for landscapers and such. I cant seem to find it right now however. It has to be in 5 gallon or less DOT approved cans and there is an overall quantity limit. I thought I remember 11 Gallons. Which is about 66lbs.
#11 CaseyWorkman
CaseyWorkman
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 15 January 2016 - 05:48
I think you must have solved your query by now but in future if you have the same issue then you can think of hiring an oversize hauling service of a company.
Content Spy
HeliHelmets-VR HomeBLR 200MaunaLoaVRHome200Genesys VR Forum 200Spectrum_VRHome200FreeFlight_Home200PrecisionVRForumHome200
