MckeeC Posted October 1, 2015 Report Share Posted October 1, 2015 So I went to take my aviation physical (the last portion of my packet) today at Fort Drum. Last December I had lasik and since my eyes have been amazing. I've had no problem and everything has looked great as far as my eyes go. I found out today though my eyes don't pass the standards for the pressure (puff) test. They are a 6 and I was told they need to be a 7 to pass. So I'm wondering if anyone else has had this issue or knows the process of getting a waiver and if that's possible for this. I've been in the WOFT process for over a year now. I got lasik just to do this and now it seems that at the last step I may be done. Any suggestions? Quote Link to comment Share on other sites More sharing options...
AFmarksman Posted October 1, 2015 Report Share Posted October 1, 2015 Did they specifically tell you that you were disqualified? The Army Aeromedical Policy Letters state the following: "No waiver is required for low IOP (IOP of 7.0 mm Hg or lower) and will be filed as Information Only after a normal investigation below." "Low IOP:If a low IOP of 7 mm Hg or less is confirmed by Goldman’s Applanation Tonometry done by an optometrist or ophthalmologist, then document the following:- Corneal Pachymetry- Slit lamp examination to rule out underlying pathology or refractive surgery." "No follow- up is required for ocular hypotension (low IOP). Persistent ocular hypotension on future FDME/FDHS will be listed as “Information Only” if the initial evaluation is normal." As long as you have a normal investigation, as stated, you shouldn't need a waiver. 1 Quote Link to comment Share on other sites More sharing options...
MckeeC Posted October 1, 2015 Author Report Share Posted October 1, 2015 I appreciate that info. So there is still hope! Do you have the regulation you got that from so I can give it to my recruiter to look into? Quote Link to comment Share on other sites More sharing options...
AFmarksman Posted October 1, 2015 Report Share Posted October 1, 2015 The Army Aeromedical Policy Letters are located here: http://www.rucker.amedd.army.mil/assets/documents/pdf/army_apls_28may2014.pdf 1 Quote Link to comment Share on other sites More sharing options...
Lindsey Posted October 1, 2015 Report Share Posted October 1, 2015 If you can afford it, and it comes down to it, you could try to get the test done at Rucker. At the very least they'd be the final authority on it, anyway. Quote Link to comment Share on other sites More sharing options...
MckeeC Posted October 1, 2015 Author Report Share Posted October 1, 2015 Thanks a bunch! We're going to definitely look into this. And Lindsey, I'm not sure it would be practical to ever get down all the way to Fort Rucker. I live in upstate New York so that's a few days drive. If it comes down to either going to Rucker or having no chance though you can bet I'll do whatever is necessary. Quote Link to comment Share on other sites More sharing options...
shainbourassa Posted October 2, 2015 Report Share Posted October 2, 2015 Thanks a bunch! We're going to definitely look into this. And Lindsey, I'm not sure it would be practical to ever get down all the way to Fort Rucker. I live in upstate New York so that's a few days drive. If it comes down to either going to Rucker or having no chance though you can bet I'll do whatever is necessary.Flights are fairly cheap if you fly to PCB or ATL. Quote Link to comment Share on other sites More sharing options...
itsbigfootguys Posted October 2, 2015 Report Share Posted October 2, 2015 If you can afford it, and it comes down to it, you could try to get the test done at Rucker. At the very least they'd be the final authority on it, anyway.I recommend this to every person who wants to apply. No shortage of flight surgeons and far less bs. Quote Link to comment Share on other sites More sharing options...
FTG19 Posted October 28, 2015 Report Share Posted October 28, 2015 Samething happened to me at drum and then we deployed. Didn't know they still had WO recruiters there because drum is not on the usarec site anymore. Quote Link to comment Share on other sites More sharing options...
