Helicopter AcademyVOLO_VRHome200TigerTugsFrasca VRForum468
Satloc Users
  • Please log in to reply
5 replies to this topic
#1 TonarHerocopterPilot
    Newbie
  • Members
  • Pip
  • 9 posts
Posted 24 May 2016 - 12:55
My cross track light bounces back and forth a lot when I'm flying and 1 / 0 feet off. Using 1,2,3,5 degrees for my lower light bar, top bar is 1,2,3,4,5 feet on the lights respectively. Messing with the refresh rate on the GPS, Standard was programmed at 20HZ. Wondering what some people used for their HZ. Anyone have this problem of flickering back and forth real fast? It's a Bantam with an L7 light bar. Flew a G4 and M3 before and didn't have this annoyance. What set ups are you running for lights, HZ etc?
#2 Rotorhead84
Rotorhead84
    VR Veteran Poster
  • VR Member
  • PipPipPipPipPipPipPip
  • 148 posts
  • Gender:Male
Posted 21 June 2016 - 10:53
give me the commands to check the Hz rate and I'll look at our 3 units.  (If we have batteries in the aircraft, batteries might still be out.
I had no idea you could even check the Hz rate.
And you mean the light goes from left side to right side?  or?
Edited by Rotorhead84, 21 June 2016 - 10:54.
#3 TonarHerocopterPilot
    Newbie
  • Members
  • Pip
  • 9 posts
Posted 21 June 2016 - 21:40
I'll be on swath, holding zero feet (for a majority of the pass at least) and the lower lights flicker from right to left even while holding a swath damn good. I have the lower light set to 2 degrees. I'll check in the morning but if you go under GPS setting and go through a few setup screens i believe its there. I think the options are 20, 10, 5
#4 rotormandan
rotormandan
    VR Veteran Poster
  • VR Member
  • 667 posts
Posted 21 June 2016 - 23:30
Not a helpful answer, but I didn't know people used 2 lightbars?
#5 Rotorhead84
Rotorhead84
    VR Veteran Poster
  • VR Member
  • 148 posts
  • Gender:Male
Posted 23 June 2016 - 00:02
Lightbars have a row of lights at the top and a row of lights at the bottom.  You can set them for different things
#6 R22139RJ
R22139RJ
    VR Veteran Poster
  • VR Member
  • 257 posts
  • Gender:Male
  • Interests:Flying
Posted 25 June 2016 - 13:56
I swapped helicopters, Bantam GPS with an older lightbar and no problems. The settings for current unit are 20HZ. I'm going to save the pilot setting from current unit and input them to old. We have an L model with the L7 lightbar and its doing the same thing.
  • R22139RJ likes this
Spray it Right, Spray it Tight
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
Content Spy
Genesys VR Forum 200BLR 200FreeFlight_Home200Spectrum_VRHome200MaunaLoaVRHome200PrecisionVRForumHome200HeliHelmets-VR Home
