Will Lithium Ion batteries ever have the energy density to be used in rotorcraft?
There's been a lot of talk recently about electric airplanes and possibly also rotorcraft and I was wondering if you guys think it's total bogus or potentially viable?
I've heard that lithium ion batteries have less energy density that newspaper!
One factor for electric flight is the battery weight stays the same, charged or discharged. Conventional fuel is burned off during flight effectively getting a bit more flight time due to lighter aircraft.
Doubt we will see this for a while. But when every house has solar and battery banks, then the tech may be getting close. I feel much of this is proof of concept to obtain research grants.
Turbines are quite the perfect engine for thrust v weight. Hard to replace in the near future.
Great point
Is that a comparison for when the lithium ion batteries catch fire?
Well I guess what they mean't is that if you convert volts to BTU you can burn newspaper and get more BTU per amount of mass than Lithium.
I did some math and found that JET A has 550 BTU/per cubic inch and lithium ion has 30 BTU/cubic inch. One gallon is 231 cubic inches.
So considering that most turboshaft engines have a power/weight ratio of 4:1 it doesn't seem that lithium ion will amount to anything.
So for lithium ion to work they would need to increase the energy density by 520 times!!
