Frasca VRForum468Helicopter AcademyVOLO_VRHome200TigerTugs
AS350B3 vs B3+
  • Please log in to reply
3 replies to this topic
#1 rowncounter
rowncounter
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 08 September 2017 - 12:36
Can anyone with lots(copious amounts) of longlining in B3 and B3+ tell me the difference in  lift capabilities?. ie. How much better is the B3+ for lifting? As well, some comments of what the B3e will actually lift??
thanks
#2 HawaiiCFII
HawaiiCFII
    CFI Poster
  • Members
  • PipPipPipPipPip
  • 43 posts
  • Gender:Male
  • Interests:Helicopters, skiing, motorcycles, scuba diving, and Ahhh-laaas-KUUHHHH!
  • Company working for:Temsco
Posted 10 September 2017 - 14:42
What do people mean by B3+? Where did this term this come from?
I'm guessing the 2B1 model?
I think of them as the 2B, the 2B1, and the B3e.
The max external weights are the same for all of the B3 models (6173 lbs). The B3e has a more powerful engine that will mostly make a difference in a high, hot, heavy scenario.
The 2B1 and the B3e both have a fadec and the anti-Torque pedals are linked to it. So if you are pulling in a lot of power and have the right pedal in far enough it will increase rotor rpm NR up to 405 (normal NR is around 394).
#3 AS350 pilot
AS350 pilot
    VR Veteran Poster
  • Members
  • PipPipPipPipPipPipPip
  • 108 posts
  • Gender:Male
  • Company working for:Utility
Posted 11 September 2017 - 16:57
I've flown the B2 a lot and the B3e for a few hundred hours but never a B3. The most impressive lift I've seen weight wise was 2500 pounds in the B3e at sea level around 20 degrees C. The best I've seen it do at altitude was 6,000' on a cool day pick 2,000 lbs. Both scenarios were very light on fuel.
The B3e has a higher hp number then the B3 but you may have a hard time finding the actual numbers lol...I've even asked the tech reps and can't really get a straigh answer. As with all manufacturers the machine is getting heavier every year so you're best lifter would be an early B3e....around 2012 model. The B3 and B3e have the same external gross weight numbers so the way to get more on the hook is to have as light a machine as possible. Some have dual hyd and it actually doesn't add all that much weight; however, the astar can be flown competently with a complete hyd failure.
Hope that helps.
#4 HawaiiCFII
HawaiiCFII
    CFI Poster
  • Members
  • PipPipPipPipPip
  • 43 posts
  • Gender:Male
Posted 12 September 2017 - 18:35
By the way, I've only flown the 2B1 model and I haven't done any slinging in the B3 so I'm not the expert you are looking for. I looked at the RFM for both of them and they OGE and IGE charts look the same.
Hopefully someone else chimes in.
Content Spy
Spectrum_VRHome200PrecisionVRForumHome200FreeFlight_Home200HeliHelmets-VR HomeMaunaLoaVRHome200Genesys VR Forum 200BLR 200
