FRASCA FT468Tampa Bay VR FT Forum 468Helicopter Academy
Which is more common?
  • Please log in to reply
10 replies to this topic
#1 r22butters
r22butters
    VR Veteran Poster
  • VR Member
  • PipPipPipPipPipPipPip
  • 2,100 posts
  • Gender:Male
  • Location:Pluto,...at least until the next election :) ,...damn the wifi here is unbelievable!
  • Interests:Admiring the city lights and coastal sunsets from a thousand feet,...when I have the dough. :)
    ,...oh' yeah, and boobs!
  • Company working for:Just a happy casual renter! :)
Posted 15 November 2017 - 13:18
Seems the first argument I hear when it comes to training in a Cabri (Schweizer in the old days) vs. a Robby, is the teetering rotor system. So which situation are students more likely to get into?
#2 takefootoff
takefootoff
    VR Veteran Poster
  • VR Member
  • 308 posts
  • Gender:Male
Posted 15 November 2017 - 14:02
in my limited experience with the 300s, I only got into ground resonance like 4 times over the course of approx 700hrs. and it was always in one particular ship out of three available
#3 r22butters
r22butters
    VR Veteran Poster
  • VR Member
  • 2,100 posts
  • Gender:Male
Posted 15 November 2017 - 14:26
Around 700 hours between 35 different R22's,...zero low-G and/or mast bumping!
Looks like you got me beat! :D
#4 DizzyD
DizzyD
    VR Veteran Poster
  • VR Member
  • 95 posts
Posted 15 November 2017 - 14:28
Only one of these threats was deemed hazardous enough to require its own Special FAR.  Also, one of the local G2 operators has experienced no issues with ground resonance and I hear that having the skids connected to the fuselage by elastomeric mounts instead of being bolted directly on has reduced ground resonance occurrence.
The 300 has some form of skid damping as well correct?
Edited by DizzyD, 15 November 2017 - 14:39.
#5 Eric Hunt
Eric Hunt
    VR Veteran Poster
  • VR Member
  • 864 posts
  • Gender:Male
Posted 15 November 2017 - 16:22
Ground resonance will only come if something is wrong with the aircraft - drag damper, oleo, tire pressure.
Zero G will only come if something is wrong with the pilot - didn't listen to thousands of people telling him DO NOT PUSH OVER!
  • RockinRob likes this
#6 Hand_Grenade_Pilot
Hand_Grenade_Pilot
    VR Veteran Poster
  • VR Member
  • 167 posts
  • Gender:Male
  • Company working for:GoM
Posted 15 November 2017 - 20:42
Its's pretty easy to get ground resonance in the S300. Experienced it dozens of times over the course of two years and about 1100 hours while instructing. Usually from a sloppy setdown on rough/uneven pavement and on a few occasions while doing run-on landings to a runway. Definetly a topic I stressed w/ my students (recognition and recovery). No expereince w/ the Cabri so can't comment on that.
Experienced it only once in an MD500. Never in the AS350 or 407, although it is possible.
Only encountered low-g roll once, while flying an R44 in Hawaii. A massive updraft caused the rotor to become unloaded resulting in a rapid, uncommanded right bank. Instinctively moved the cyclic back which immediately leveled the helicopter. Was a fascinating expereince to say the least; until that point I had thought it could only occur as a result of doing a hard pushover with the cyclic.
So I'd say ground resonance is a much more common experience. Also worth noting that any helicopter can experience a low-g induced roll (but only teetering rotor systems are subject to mast bumping).
Aviation is a cruel mistress. When she's not taking your money, she's coming up with creative ways to kill you.
#7 Wally
Wally
    VR Veteran Poster
  • VR Member
  • 1,674 posts
  • Gender:Male
  • Company working for:none
Posted 16 November 2017 - 20:34
I can't argue with your theory on ground resonance, except that it can be induced in an aicraft that has no apparent mechanical issue, and I think- in a sound aircraft if you work really hard at it. Seems to me that I encountered ground resonance on run-ups and then it doesn't just happen, it sort of indicates that something is wrong, rocking and rolling unusally before the full ground resonance thing starts happening.
Or it can happen as you land in an otherwise serviceable aircraft if you isolate part of the damping mechanism, the running landing with one skid down first and a jar to the system to upset the rotor. Soft/hard oleos on the 300 skids, hanging an Astar skid heel off the deck or the skid tub on a rock- and a jar to the airframe can set it off. Again, you just stop what you're doing and change things when you land again. None of this is uncommon in the real world, but it probably won't kill you. Aerospatiale says 'dynamic divergent excitation' (ground resonance) can happen in flight...
Teetering rotors and low G can be over much quicker- unloading the main rotor and not controlling the aircraft appropriately ended some Huey pilot's Vietnam tour early. Didn't this very problem underly the Robinson's SFAR?
Don't be stupid with either rotor and you'll be fine.
#8 RockinRob
RockinRob
    Student Poster
  • Members
  • PipPip
  • 12 posts
  • Gender:Male
  • Interests:Climbing, fishing, canoeing, rafting, skiing, etc
  • Company working for:Aerial Applicator
Posted 17 November 2017 - 10:55
I flew the 300 for about 100 hours of my initial training.
Experienced ground resonance once on a running landing, recovered to a hover and set back down.
Had one stick a valve in a hover and settle, ground contact lead to gr, recovered to a hover and set back down. (this one happened after a fuel stop on solo x/c)
I have 2k or so hours in 22s, 44s, and 66s at this point; including some more "aggressive" turning maneuvers in aerial application environments, and a fair amount of mountain flying.
Never experience low g in years in Robbies.
I think proper pilot education and training on avoidance, recognition, and recovery of these dangerous scenarios does wonders to aid in the overall safety and longevity of our rotorcraft brethren.
#9 Boatpix
Boatpix
    VR Veteran Poster
  • VIP Member
  • 284 posts
Posted 13 December 2017 - 07:56
The R22 is simpler and cheaper to fly.
Tom McDermott, manager
HelicopterAcademy.com/BOATPIX
#10 johnnyb
johnnyb
    CFI Poster
  • Members
  • PipPipPipPipPip
  • 42 posts
  • Gender:Male
Posted 07 January 2018 - 13:35
Nope.
I've experienced GR multiple times in different aircraft including the 300 and the Astar, instances where there was nothing wrong with the aircraft.
Direct results of the surface of a specific uneven helipad, or a skid touching down just a little too hard.
  • Wally likes this
"You cannot propel yourself forward by patting yourself on the back."
#11 helicodger pilot
helicodger pilot
    ATP Poster
  • VR Member
  • 52 posts
Posted 28 January 2018 - 19:23
Yes, but...
Ground resonance is seldom fatal but mast bumping usually is.  True or not?
"I'm not arguing, I'm just explaining why I'm right"
Content Spy
VOLO_VRFT200BLR FT 200JerryTrimbleUNDVRFTForum200GuidanceVRFTForum200Precision_FTForum200LakeSuperior200FlightTrainingAnthelion_VRFTForum200Arkansas Helicopters VR FT200702HeliVRFT200
