Mobile1 Posted April 19, 2019 Report Share Posted April 19, 2019 Lately I have been seeing helicopters that have no tail rotator. How does this work? Quote Link to comment Share on other sites More sharing options...
Micah4 Posted April 19, 2019 Report Share Posted April 19, 2019 I believe its the NOTAR system. Google can give you a better answer than me but it basically blasts air out of a port hole in the tail to counter the rotors rotation. Quote Link to comment Share on other sites More sharing options...
iChris Posted April 19, 2019 Report Share Posted April 19, 2019 (edited) Lately I have been seeing helicopters that have no tail rotator. How does this work? To gain a basic understanding check out the two links below. The first link outlines the NOTAR system, likely the system you’re seeing. The last shows how other helicopters eliminate the conventional tail rotor. Hereafter, you’ll have a basic reference for specific questions. The means and techniques used to counter main rotor torque from an engineering standpoint are about the aerodynamics and Newton’s third low, action-reaction. Aerodynamics is concerned with the motion of air and the forces acting on objects in motion through the air. In effect, aerodynamics is concerned with the object (aircraft), the movement (relative wind), and the air (atmosphere). Basic laws of motion, fluid flow, and forces acting on an aircraft. Links: NOTAR (NO TAil Rotor) Technology How can a helicopter be designed without a tail rotor? Edited April 19, 2019 by iChris 1 Quote Link to comment Share on other sites More sharing options...
