VOLO_VRHome200Helicopter AcademyFrasca VRForum468TigerTugs
Blood pressure medication
  • Please log in to reply
7 replies to this topic
#1 Adriek64
Adriek64
    VR Veteran Poster
  • Members
  • PipPipPipPipPipPipPip
  • 112 posts
  • Gender:Male
Posted 30 July 2019 - 22:35
Long story short. went in today for a part 2 physical and out of nowhere my blood pressure came up to 155/85. I have never had any issues and have a VERY clean medical record. Doc wont send the physical to Rucker (guaranteed grounded) until figuring out if it was just an abnormality or I need medications, which he made it seem like it's not a big deal. Has anyone taken blood pressure medications and not get grounded. I still got my upslip for what is worth.
#2 z0na
z0na
    ATP Poster
  • Members
  • 55 posts
  • Gender:Male
Posted 31 July 2019 - 04:52
You have the same resource available to you as your Flight Surgeon. Take a look at the Aeromedical Policy Letter and use CTRL + F. Youll learn very quickly that taking blood pressure medication is NOT a disqualifying factor.
  • Adriek64 likes this
#3 LordByron423
LordByron423
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 31 July 2019 - 10:31
Had you eaten within 30 mins of getting your BP done? Eating elevates your BP. Or you might have "White Coat Syndrome". My BP was 141/72 at my part 1 of my physical. My BP always measures in the mid 130s at doctor's offices, but when I do it at home I'm in the 120s or below. My friend who is physician assistant did my BP as well and it was 121/70.
White Coat Syndrome is a mental thing where you get hypertensive when ever getting a medical exam done. https://en.wikipedia...at_hypertension
#4 SwissK31
SwissK31
    VR Veteran Poster
  • Members
  • 84 posts
Posted 31 July 2019 - 16:24
When I did my initial flight physical, I was a bit high on the pulse/BP.  I suppose it was that "white coat syndrome." The Flight doc just let me sit a while to relax and tested two more times, and it was fine.
I've also seen it mentioned that they can put you on a 24 hour BP/Pulse device.
But as z0na mentioned, taking BP medicine isn't a dis qualifier.  My concern would be that you are taking BP medicine needlessly, and that your high BP was just a product of anxiety.  Taking medicine could just end up causing issues on the other side of the blood pressure scale if you don't actual have high blood pressure.  .
#5 Adriek64
Adriek64
    VR Veteran Poster
  • Members
  • 112 posts
  • Gender:Male
Posted 31 July 2019 - 19:09
I can't figure out what happened yesterday! went in today and BP was back to my normal, which has always been in the high 120s to low 130s. yesterday was just crazy... it read 150/75. I was freaking out but hopefully it was just a fluke!
  • mike0331 and SwissK31 like this
#6 mike0331
mike0331
    VR Veteran Poster
  • Members
  • 512 posts
  • Gender:Male
  • Interests:Freedom & 'Merica
  • Company working for:USMC Infantry, Lawyer(ish)
Posted 06 August 2019 - 19:42
White coat is super common. Also if you workout a little make sure they use the bigger cuff. If the machine keeps showing high, have a tech do it manually. I get whitecoat all the time for whatever reason. I've been in the same boat with almost the same numbers.
#7 Adriek64
Adriek64
    VR Veteran Poster
  • Members
  • 112 posts
  • Gender:Male
Posted 06 August 2019 - 19:47
Doc had me coming in for 5 straight days... each day BP has been normal!
#8 klas
klas
    VR Veteran Poster
  • VR Member
  • 375 posts
Posted 08 August 2019 - 12:14
That happened to me, too.  Went in for physical, the top number was high, bottom normal.  Then they made me wait two more hrs to take 2 more measurements and they were normal.  They had me go to private doc - did so 3 different occasions.  Each time normal almost low.  That is when I had a resting pulse rate of 40 (good old days...).  Went back for physical again and same thing happened as 1st  - top number high and later numbers normal.  They STILL didn't take me.  It was only after I relaxed and talked to neighboring recruits did I calm down and have fun were the numbers normal on later tries.  But the white coat syndrome got me.
Content Spy
LakeSuperior200PrecisionVRForumHome200Spectrum_VRHome200Genesys VR Forum 200MaunaLoaVRHome200BLR 200HeliHelmets-VR HomeGuidance Home 200FreeFlight_Home200
