Would you be interested?
Study Guides
44 members have voted
  1. 1. Would you buy an indepth study guide aimed at commercial students?
    • Yes
      34
    • No
      10
  2. 2. Do you already own a study guide you bought previously?
    • Yes
      13
    • No
      31
  3. 3. Look at the contents of the guide posted, would you be interested in buying such a study guide? (Roughly 500+ questions total)
    • Gimme-Gimme!
      31
    • No thanks
      13
One thing I have learned in many years of college and medical tests;
always pick out the key words, as lots of you know, the always, never, first, last, shoulds, onlys, excepts, and a few others.
also, statistically, answer B in multiple choice is the correct answer more than all of the others.
another tip is when answering multiple choice. USUALLY, if two answers are saying pretty much the same thing, in a round about way, or very closely related, you can throw those two answers out. If two of the four answers are polar opposites, the answer is usually one of those two.
and always find exactly what the question is asking and pick not just one of the correct answer, but pick the answer that is most correct. most being the key word/.....
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
West Coaster,
I am working on devloping a web site for flight training at www.part61.org. Maybe we can colaborate? If you PM me your email I can send you about 30 pages of questions and answers I am working with for my website.
Permison
I am working on devloping a web site for flight training about 30 pages of questions and answers
post a few HERE permison?---we all like learning what we do & dont know at question & answer time :)
Sure, most of these are from the private test. I am trying to build a online test specific to helicopters.
1. For aircraft certification, what is an example of an aircraft class?
A. Normal
B. Robinson R22
C. Rotorcraft
D. Helicopter
2. The curved shape of an airfoil’s upper surface tends to ______________ airflow over it
A. Accelerate
B. Decelerate
C. Stall
D. Dissipate
3. The tendency of a helicopter to drift laterally in the direction of tail rotor thrust is called
A. translating tendency
B. translational lift
C. traverse flow effect
D. dissymmetry of lift
4. The cyclic inputs to a swash plate are 90 degrees before the blade reaches the point of required reaction due to
A. blade flapping
B. gyroscopic precession
D. cyclic rigging
5. If you suspect detonation during climbout, the normal corrective action is to
A. lean the mixture
B. apply carb heat
C. increase rate of climb
D. reduce the power setting
6. During the preflight inspection, the fuel strainer should be drained and primarily checked for the presence of
A. Metal particles
B. Oil
C. Air
D. Water
7. The freewheeling unit/sprag clutch allows the _______________ to turn if the engine fails
A. Tail Rotor
B. Main Rotor
C. Oil Pump
D. Alternator
8. The angular difference between the true north pole and the magnetic north pole is called
A. deviation
B. agonic difference
C. variation
D. wind correction angle
9. When you are flying you should spend at least what amount of time looking outside?
A. 50%
B. 70%
C. 80%
D. 90%
10. A closed runway or taxiway will be marked with
A. a 'closed' sign
B. red warning lights
C. amber flashing lights
D. an 'X'
11. Class A airspace extends upward from
A. 12,500 feet MSL
B. 18,000 feet AGL
C. 18,000 feet MSL
D. 18,400 feet MSL
12. If ATC gives you a clearance that compromises your safety or would cause you to violate a regulation, you should
A. comply with it
B. continue as planned
C. refuse the clearance
D. Request an amended clearance
13. Which transponder code alerts air traffic control to an aircraft experiencing an emergency?
A. 1200
B. 9911
C. 7600
D. 7700
14. The performance envelope of an aircraft is defined by its
A.Weight
B. Operating Limitations
C. Forward Airspeed
D. Horsepower
15. Where is the most current basic empty weight and moment for a helicopter listed?
A. In the owners manual
B. On the Airworthiness certificate
C. On a placard in the cockpit
D. In the weight and balance records
16. The imaginary circular plane outlined by the rotor blade tips as they make a cycle of rotation is the
A. Pitch angle
B. Tip path plane
C. Chord line
D. Angle of attack
17. The purpose of lead-lag (drag) hinges in a three-bladed, fully articulated rotor system is to compensate for
A. Blade flapping
B. Dissymmetry of lift
C. Translating tendency
D. Coriolis effect
18. On an R22, applying left pedal pressure
A. Decreases the pitch of the main rotor
B. Increases the pitch of the main rotor
C. Decreases the pitch of the tail rotor
D. Increases the pitch of the tail rotor
19. If the oil temperature is abnormally high, it may be the result of
A. A plugged oil line
B. Too much oil in the engine
C. A dirty air filter
D. Operating with the mixture too rich
20. In terms of engine power, using carb heat will result in
A. No change
B. A decrease in power
C. An increase in power
D. Initially a decrease, then an increase
21. On an R22, the tail rotor is
A. A teetering system
B. A Fully-articulated system
C. A rigid system
D. A teetering system with coning hinges
22. International Standard Atmosphere (ISA) conditions include
A. Sea level temperaure of 15 degrees C and a an atmospheric pressure of 29.99 inches of mercury
B. Sea level temperaure of 2 degrees C and a an atmospheric pressure of 29.92 inches of mercury
C. Sea level temperaure of 15 degrees C and a an atmospheric pressure of 29.92 inches of mercury
D. Sea level temperaure of 15 degrees C and a an atmospheric pressure of 30.00 inches of mercury
23. What aircraft has right of way over all other aircraft?
A. Glider
B. Airship
C. Balloon
D. Aircraft in distress
24. When operating at an airport, helicopters must
A. Never land on the runway
B. Always perform an "overhead join"
C. Avoid the flow of fixed wing traffic
D. Shut down the engine before entering the ramp
25. If you depart an airport in the Central Standard Time Zone at 1300 hours Zulu, and arrive in a city on the west coast two hours later, what is your arrival time?
A. 1100 Z
B. 1300 Z
C. 1500 Z
D. 1700 Z
Nice, your 100% so far! You've done this before ;-p
thanks :) & yip i have taken plenty of tests in my day---but ya know what? its still the learning & teaching others that really "makes my day" :rolleyes: ;)
Guest rookie101
Still learning here so don't be too surprised if I am way off. I numbered it every 5th time as it's easier on me and if you get lost it should be pretty easy to find the answer.
C
A
A
B
A (5)
D
B
C
D
B (10)
C
D
D
C
B (15)
B
D
C
B
B (20)
A
C
D
A
D (25)
C
A
A
B
A (5) (Wrong Answer)
D
B
C
D (Wrong Answer)
B (10) (Wrong Answer)
C
D
D
C (Wrong Answer)
B (15) (Wrong Answer)
B
D
C (Wrong Answer)
B (Wrong Answer)
B (20)
A
C
D
A (Wrong Answer)
D (25) (Wrong Answer)
Ok Rookie, you missed 9 out of 25. Not bad. Go back and check your answers and then I will post another 25 or so questions.
  • 1 month later...
A. Tail Rotor
B. Main Rotor
C. Oil Pump
D. Alternator
My answer: Both A and B
And IF the oil pump in this case is for hydraulics powered by the M/R transmission?-then C is correct also
And IF the alternator is driven by transmission too?-then D is also correct
This question is worded typical of FAA questions, it sometimes can appear to have TWO or more correct answers, the key to remember tho & orient your thinking while taking these type of tests is: Which answer is "more correct",,,, sounds silly i know, but thats the way it is. :blink:
Sometimes logic helps to weed out the more correct answer too,,,,think of the answers in this way: "now why would one design a helicopter drive train system so that when the engine quits, the main rotor locks up too, but still allows the tail rotor to spin?" :unsure:
A is correct, but B is more correct. ;)
Edited by pokey
