RotorPilot Posted June 25, 2003 Report Share Posted June 25, 2003 Does somebody know if there is a way to upload and store in this server a personal avatar ? I want to change mine to use the same one in all Forums, I don't have a server where to put it and don't find the option to upload it Any ideas ? RP Quote Link to comment Share on other sites More sharing options...
Guest Posted June 25, 2003 Report Share Posted June 25, 2003 I'll check into programming one... -Rey Quote Link to comment Share on other sites More sharing options...
Guest Posted June 25, 2003 Report Share Posted June 25, 2003 You can upload your own avatar now. The limit is 50 K for the image size. You will see the option in your control panel, under personal info, avatar options. Let me know if it works for you okay. -Rey Quote Link to comment Share on other sites More sharing options...
RotorPilot Posted June 26, 2003 Author Report Share Posted June 26, 2003 Hi Rey It worked !!! Computers are magnificent (when they work) I will upload a better resolution image of the same one. Need to know the max. size in pixels. I used a 45X45 - 6k image but I will have the same one a little bigger and with a better resolution if possible to upload Thanks RP Quote Link to comment Share on other sites More sharing options...
HeliFrank Posted June 26, 2003 Report Share Posted June 26, 2003 Cool option, Rey...Keep up that good work. Frank Quote Link to comment Share on other sites More sharing options...
Guest klas Posted June 26, 2003 Report Share Posted June 26, 2003 I must be dense, because I don't see a personal info, avatar options anything.... Can you point me to where it may be ? Quote Link to comment Share on other sites More sharing options...
RDRickster Posted June 26, 2003 Report Share Posted June 26, 2003 Klas, you need to register and logon. Then click "Control Panel" (upper left of browser). Quote Link to comment Share on other sites More sharing options...
klas Posted June 26, 2003 Report Share Posted June 26, 2003 Klas, you need to register and logon. Then click "Control Panel" (upper left of browser).Ah, got it. Thanks. Quote Link to comment Share on other sites More sharing options...
