montu Posted November 15, 2008 Posted November 15, 2008 I've been flying in the 300C for awhile now and tomorrow I will be flying in a 300CBi what is the wind speed limits for the CBi. I know 300C is 17 knots. thanks Jordan Quote
Tawler Posted November 15, 2008 Posted November 15, 2008 I don't have the book in front of me ...but as far as I can recall it's the same. Quote
HelliBoy Posted November 15, 2008 Posted November 15, 2008 There is no limitation. Read your POH. It says something along the lines of "directional stability has been demonstrated up to 17kts of wind speed." Its not a limitation, its a CYA. >30kts and you'll be fine, if uncomfortable. Just dont get downwind low and slow. And it is the same for both. Quote
AngelFire_91 Posted November 15, 2008 Posted November 15, 2008 I concur with Heliboy, it's not a limitation. I've been out in the 300C in winds 35G40 kts with no problem. Just be aware of your adverse wind angles, make sure you keep on the pedals, and don't let her get away from you. Quote
Hedge36 Posted November 15, 2008 Posted November 15, 2008 The CBi prefers it's wind from the left side, don't recall if the 300C really cared. Everything else (except not having to worry about carb heat and probably an auto-engage clutch) is the same. Quote
montu Posted November 15, 2008 Author Posted November 15, 2008 Wow. I don't think I've ever flown in those type of winds. Tomorrows wind are forecast to be gusting 17kts or so. I heard from some one awhile ago that the CBi could handle a little more wind than the C model. They said because of the size of the vertical stabilizer . Jordan Quote
Hedge36 Posted November 15, 2008 Posted November 15, 2008 Could be. I think you'll find your legs wear out before the bird reaches any sort of limit, though Quote
Goldy Posted November 16, 2008 Posted November 16, 2008 20 plus knots?? Piece of cake in a 300. At least you can hold altitude, try it in a R22 sometime ! Quote
Tawler Posted November 16, 2008 Posted November 16, 2008 i just got owned. haha. but i should correct what i said and say that i did mean it as it being a "recommendation" not a "limitation". :x Quote
Mungo5 Posted November 17, 2008 Posted November 17, 2008 It's the gust spread you want to watch out for. 20G30 is a 10kt spread and on the edge of too much for me. Quote
JDHelicopterPilot Posted November 17, 2008 Posted November 17, 2008 I see a trend here. Many pilots have different opinions on wind speed. As said it's just a demonstrated speed which is posted in the POH. That doesn't mean the helicopter will not handle higher winds. The highest wind I have been in is 50-55knts. That was in the EC130. That you have to be careful with. LTE and an over torque would be easy at that point in the EC130. The point I am leading up to is each pilot needs to have their own limitations. What are you comfortable with? Be conservative. As time goes on you can evaluate your limits and make adjustments. That would come with experiance and aircraft handling. When I first started flying the Astar we had the Santa Ana winds blowing one day. I didn't have much time in the aircraft. With the wind pushing 40knts from a weird direction I decided to ask a more experianced pilot if she wouldn't mind taking my flights for me. Pilots can't be afraid or ashamed to admit their limits, ask for help or advice and learn from it. Quote
