I go to forums drop down chose help put in helmets search says nothing found ? what am I doing wrong
> Help Topic
Here is the topic you chose to view
Enter keywords to search for
> Searching Topics and Posts
The search feature is designed to allow you to quickly find topics and posts that contain the keywords you enter.
There are two types of search form available, simple search and advanced search. You may switch between the two using the 'More Options' and 'Simple Mode' buttons.
Simple Mode
All you need to do here is enter in a keyword into the search box, and select a forum(s) to search in. (to select multiple forums, hold down the control key on a PC, or the Shift/Apple key on a Mac) choose a sorting order and search.
Try changing your avatar.. It conflicts with your name and most likely confuses the system
