Pohi Posted December 26, 2009 Report Share Posted December 26, 2009 Why all the focus on only doing the minimum required.? I don't think it has anything to do with squeaking by with the bare minimums. Personally it is more of a combination of boredom and just an issue with the ability to read the regulations. Any excuse to avoid the family around the holidays :-D Link to comment Share on other sites More sharing options...
bossman Posted December 26, 2009 Report Share Posted December 26, 2009 I like that quote. Question: Has anyone signed off the add-on rating using IACRA using the 19 hours. Does it accept it or kick it out? I'm sure it does to same thing no matter what part of the country one is in. I was always on the 19 hour side. One needs 20 hours of dual(not specific in any category) AND 10 hours solo of 61.107((1) but I can see how both the dual and solo can be interpreted for 61.107((1). In my experience it never mattered because I always taught in Robbies which needed 20 hours dual anyway per the SFAR so I never tried it out in IACRA. Any instructors in other ships care to answer?We have done about 17 using IACRA with 20 hours. Sometimes they are kicked back with a question, but never because of not enough hours. Link to comment Share on other sites More sharing options...
rotormandan Posted December 26, 2009 Report Share Posted December 26, 2009 Then I think that there would be the answer. Not that IACRA is perfect but if it accepts the 19 hours than I would think that that would be it. The FAA designed it to kick out applications that are unqualified so they don't have to look for mistakes so much. If it goes through with 19 hours than it must be acceptable with the regs. If your examiner won't do a checkride for someone with under 30hrs for an add-on then you might want to ask them about that or find a different examiner, or just eat the extra hours if you still want to use that examiner but can't convince him/her. Link to comment Share on other sites More sharing options...
Pohi Posted December 27, 2009 Report Share Posted December 27, 2009 Then I think that there would be the answer. Not that IACRA is perfect but if it accepts the 19 hours than I would think that that would be it. The FAA designed it to kick out applications that are unqualified so they don't have to look for mistakes so much. If it goes through with 19 hours than it must be acceptable with the regs. If your examiner won't do a checkride for someone with under 30hrs for an add-on then you might want to ask them about that or find a different examiner, or just eat the extra hours if you still want to use that examiner but can't convince him/her. IACRA is really screwed up. But hey, if it accepts it and you get the warm and fuzzies, then go for it. Link to comment Share on other sites More sharing options...
Pohi Posted December 27, 2009 Report Share Posted December 27, 2009 I finally, after all of this discussion, pulled out the regulations and looked at them. You guys are right, 19 hours is all that you need. Merry Christmas. Link to comment Share on other sites More sharing options...
helonorth Posted December 27, 2009 Report Share Posted December 27, 2009 (edited) Robbie Rangers..... You 2 boy should have been ticketed for PUI, we're done with the fun in this thread Edited December 27, 2009 by 67november thread closed Link to comment Share on other sites More sharing options...
