500E Posted January 12, 2010 Report Share Posted January 12, 2010 Starting to get problems loading VRSite appears to be a lot slower when contacted Sometimes there is a time out on trying to establish contact, if and when it does then there are 2 different ways it behaves 1\ it tells me I do not have the correct name or PW. 2\ it goes half way on progress bar & stops.None of the other sites such as PP & RW show the same problem. Still using FFox. Anyone else with problems?? Quote Link to comment Share on other sites More sharing options...
deanathpc Posted January 12, 2010 Report Share Posted January 12, 2010 Starting to get problems loading VRSite appears to be a lot slower when contacted Sometimes there is a time out on trying to establish contact, if and when it does then there are 2 different ways it behaves 1\ it tells me I do not have the correct name or PW. 2\ it goes half way on progress bar & stops.None of the other sites such as PP & RW show the same problem. Still using FFox. Anyone else with problems?? I noticed some slowness here and there a few times but it has always loaded up for me. I'm using IE still. Quote Link to comment Share on other sites More sharing options...
rotorrodent Posted January 12, 2010 Report Share Posted January 12, 2010 Starting to get problems loading VRSite appears to be a lot slower when contacted Sometimes there is a time out on trying to establish contact, if and when it does then there are 2 different ways it behaves 1\ it tells me I do not have the correct name or PW. 2\ it goes half way on progress bar & stops.None of the other sites such as PP & RW show the same problem. Still using FFox. Anyone else with problems?? Not having any problems at all and I'm using FFox as well. Your symptoms are very typical of a Hard Drive being within 15% of full. Check on that and if so, delete some large files and that should bring you back up to speed. Hope that helps....Cheers Rotorrodent Quote Link to comment Share on other sites More sharing options...
deanathpc Posted January 13, 2010 Report Share Posted January 13, 2010 Well I take back what I said.. Go figure... Yesterday while trying to log out I was getting an error. Something about password not correct. I shut the browser down too quickly so I couldn't read the message completely. And before you suggest it rotorrodent I just reformated my HD so I'm over 50% free!! Quote Link to comment Share on other sites More sharing options...
500E Posted January 13, 2010 Author Report Share Posted January 13, 2010 RR only 1 fifth of disc used 4\5 empty so not that problem site appears to be faster to day Quote Link to comment Share on other sites More sharing options...
Karl Posted January 14, 2010 Report Share Posted January 14, 2010 The site's been loading kind of slow for me for the last few days and I just had a can't find server page load error about 30 minutes ago. I'm using Linux Mint 8 and Mozilla.Karl Quote Link to comment Share on other sites More sharing options...
