Anyone know how to input lat & long into skyvector under the flight plan function? I put the coordinates in where it says "enter waypoints" but it does not work.
I like using skyvector for quick flight planning (of course not my only source of planning) and in my current job I get alot of coordinates. Appreciate the help!
it will work if you dont use any spaces
I.E.
37n110w
instead of
37 n 110 w
Rotorwash,
thanks. I'm still having trouble if I try to enter in the: hours, mins and seconds. Maybe I'm retarded? The example you gave does work though....
Thanks, just tried it.
It will take decimal degrees with or without ° symbol;
Or degrees w/ °, minutes w/ ', and seconds w/ ";
And converts into degrees and decimal minutes as follows- 34°18.75'N83°46.78'W.
No spaces, N/S or E/W follows coordinates.
Being a dummy and not remembering where symbols live on my keyboard, I right click GPS position on the chart, ctl c the gps coords (just to get " ° ") and then ctl v into the pop-up after clicking the "Flight plan" button, then edit the copied coords to what I want...
It won't print a course line, however. Oh well, not for nav anyhow.
Edited by Wally
Wally,
I did your method and it works perfectly, even with the Course line, just put the N/S, W/E at the end of coordinates and it gives you the Course line!
