RJP Posted May 14, 2012 Posted May 14, 2012 What is the best way to clean/polish metal main rotor blades? would you use WD40? Car Polish? 1 Quote
nightsta1ker Posted May 14, 2012 Posted May 14, 2012 I wouldnt use polish, but maybe wax. WD40 would probably just make a mess. One of my instructors mentioned using wax when he was doing some cherry drying and it gave him an extra inch or so of MP. Quote
R22139RJ Posted May 14, 2012 Posted May 14, 2012 I use Maguire's cleaner wax on the blades. I also heard at the safety course the same regarding the extra inch of manifold pressure. Quote
superstallion6113 Posted May 14, 2012 Posted May 14, 2012 Dawn dish soap works great. We used it to clean the tail rotor blades on the CH-53E, VH-60N, and the VH-3 helos when I was stationed at the Presidential Helicopter Squadron. They are always spic and span after every flight. Klasse All in One is what we used to polish them and make the leading edges shine. Quote
Flying Pig Posted May 15, 2012 Posted May 15, 2012 Car soap. Works fine on the 500. We wax them once in a while but thats when we are really bored and down for weather. Quote
Mikemv Posted May 15, 2012 Posted May 15, 2012 I suggest checking the Airframe Maintenance Manual for approved and prohibited products/substances before applying anything. 2 Quote
Spike Posted May 15, 2012 Posted May 15, 2012 (edited) IMO…. Mike is correct. Only approved consumables should be used. However, most manufactures allow for the use of Carbon-X which is a great product. Caution with the use of store bought over-the-counter soaps or polishes. Most contain sulfites which can accelerate corrosion. Dawn is often used as a default cleaner because it doesn’t contain sulfites…. However, I’ve never seen a manual approving the use of Dawn dishwashing soap. WD is debatable. If anything, only on the SS leading edge abrasion strip(s). Another item is furnisher polish on the windscreen. Debatable… One thing witnessed, if you use any kind of “lemon” furniture polish or wax, then be sure, your Plexi will turn milky over time…… Edited May 15, 2012 by Spike Quote
ridethisbike Posted May 15, 2012 Posted May 15, 2012 IMO…. Mike is correct. Only approved consumables should be used. However, most manufactures allow for the use of Carbon-X which is a great product. Caution with the use of store bought over-the-counter soaps or polishes. Most contain sulfites which can accelerate corrosion. Dawn is often used as a default cleaner because it doesn’t contain sulfites…. However, I’ve never seen a manual approving the use of Dawn dishwashing soap. WD is debatable. If anything, only on the SS leading edge abrasion strip(s). Another item is furnisher polish on the windscreen. Debatable… One thing witnessed, if you use any kind of “lemon” furniture polish or wax, then be sure, your Plexi will turn milky over time…… I believe that's anything with ammonia in it On a side note, I never thought about waxing the blades. It makes perfect sense. An inch of MP though? Never thought skin friction would have THAT much of an impact... Quote
500E Posted May 15, 2012 Posted May 15, 2012 So we wax blades? not convinced (300 500) paint finish semi-mat.We use soft brush & warm water Quote
RJP Posted May 19, 2012 Author Posted May 19, 2012 Thanks everyone. I've have heard the theory about gaining an extra inch of MP also. It makes sense. Quote
Lindsey Posted May 20, 2012 Posted May 20, 2012 We wash and wax the helicopters every 25 hours. They look (and fly) GREAT. Quote
avbug Posted May 28, 2012 Posted May 28, 2012 Waxing isn't going to produce great performance margins, but it makes getting the bugs off each time a little easier. A soft shop cloth works fine with water for washing. Any soap or any material that's left on the blade isn't good; thorough rinsing is appropriate. Turtle wax works just fine. In most cases, a simple washing with water or light mild soap is fine, followed by a thorough rinse. wax, let dry, polish off, you're done. Makes it much easier to clean next time. Quote
500F Posted May 29, 2012 Posted May 29, 2012 I've seen a set of poorly painted blades cost a 500F 250lbs of lifting capacity at max continuous, (so much for quality control)I'd believe waxing to smooth out the gaps and ridges could get some of that back. With a properly painted set of blades it should not matter. Quote
