Secret Clearance Interview
That may or may not be true. You need to go talk to your S-2 shop in your battalion about it. Depending on your background, it could take a couple months to get a clearance back. I was lucky and already had a Non-Determined Status and it was immediately approved. You might have the same situation. Only your S-2 can tell you. Go see them and they will square you away.
Also, I do not believe there is any interview required. You will fill out an incredibly detailed form, submit fingerprints, and that is about it.
 Share
