vagabondpiper Posted May 19, 2014 Report Share Posted May 19, 2014 Hy friends i am a new member over here . Brief introduction , i am military pilot , 800 hours on multi engine helicopter.This morning someone asked me what wind ie from left or right , is gonna assist me during landing in case it's a crosswind ?.Since my frist day in Aviation i have been taught in case of cross wind better keep it on power paddle. I am talking about MI 17 it has puller type tail rotor and right paddle being power paddle . So naturally my answer was wind from right but he said from left . He showed me service manual and it had mentioned in case takeoff is to be done in cross wind , preferable wind is from left . I somehow couldnt relate it with landing as in take off you are entering ETL and in landing you are getting out of ETL. Now my question is can someone throw some light on this topic. What should be the ideal wind to land in case of cross wind . Does it have to do something with LTE and does puller and pusher type tail rotor makes difference ? thanks in advance . Quote Link to comment Share on other sites More sharing options...
MALIK Posted May 19, 2014 Report Share Posted May 19, 2014 someone asked me the same question in the morning as wel, Quote Link to comment Share on other sites More sharing options...
Nearly Retired Posted May 19, 2014 Report Share Posted May 19, 2014 Welcome Vagabond! We love the PA-15! To answer your question: If I cannot land straight into the wind in an "American" helicopter (e.g. Bell), then I prefer a *LEFT* crosswind. I use the natural weathervaning tendency of the helicopter to minimize the amount of left pedal needed. I know that some pilots will vigorously argue this point. They think that if you land with a left crosswind then you WILL get into LTE. It's true because they read it in a book! I even had one guy complain about the Bell 206B with its "weak-ass" tail rotor because he landed one day when he was heavy with a *right* crosswind and nearly ran out of left pedal. Well...duh. I only have 11,000 hours of total time, mostly in Bell 206's, and I have NEVER gotten into LTE with a left crosswind... But what do I know? 1 Quote Link to comment Share on other sites More sharing options...
Gomer Pylot Posted May 19, 2014 Report Share Posted May 19, 2014 (edited) I agree. With a right crosswind, heavy, you run the risk of overtorquing if you have to put in a lot of left pedal. I've always preferred a left crosswind, and I only have a couple thousand hours more than Bob, but I've never seen LTE. Keep it slow, keep the rate of descent low, and you won't see it either. Cowboy it in, with a high rate of descent, hot, and you may see all sorts of bad things at the bottom. The 206 doesn't have a lot of TR margin to spare, but if you're smooth and careful you won't need any margin. I still have this discussion with check pilots, most of whom don't have enough experience to know what LTE really is, or what causes it. They've read the books, and answered the questions, but they don't really know how the aircraft reacts in many situations. I've had a few lately who had grey hair, but were still searching for a clue. Don't let the nose turn in the first place, and you can't get LTE. And it's easier to keep it from turning with the wind on the left. MI-17, I have no idea. Never been close to one. But the principle should be the same. Pusher or puller makes no difference, ETL makes no difference. Keep the crosswind where it takes less power to keep the nose straight. That's my opinion, and I haven't changed it in 40+ years. Edited May 19, 2014 by Gomer Pylot 1 Quote Link to comment Share on other sites More sharing options...
cburg Posted May 19, 2014 Report Share Posted May 19, 2014 Deleted comment Quote Link to comment Share on other sites More sharing options...
iChris Posted May 19, 2014 Report Share Posted May 19, 2014 (edited) Hy friends i am a new member over here . Brief introduction , i am military pilot , 800 hours on multi engine helicopter.This morning someone asked me what wind ie from left or right , is gonna assist me during landing in case it's a crosswind ?.Since my frist day in Aviation i have been taught in case of cross wind better keep it on power paddle. I am talking about MI 17 it has puller type tail rotor and right paddle being power paddle . So naturally my answer was wind from right but he said from left . He showed me service manual and it had mentioned in case takeoff is to be done in cross wind , preferable wind is from left . I somehow couldnt relate it with landing as in take off you are entering ETL and in landing you are getting out of ETL. Now my question is can someone throw some light on this topic. What should be the ideal wind to land in case of cross wind . Does it have to do something with LTE and does puller and pusher type tail rotor makes difference ? thanks in advance . They’ve taught that there’s a good side and a bad side to be avoided. That’s a generalization and over simplification of the actual flight characteristics. Both left and right crosswinds present their own unique flight characteristics. Once you learn those characteristics you’ll see it’s sometimes a pick your own poison situation (left or right). Learn the characteristics on both sides, left and right; however, don't forget the best wind is a head wind during takeoff/landing and hovering. See the following prior post on this issue: June 2013 Post: Myths and Crosswinds and Know-It-Alls Edited May 19, 2014 by iChris 2 Quote Link to comment Share on other sites More sharing options...
Azhigher Posted May 19, 2014 Report Share Posted May 19, 2014 I always prefer a right crosswind (In an Astar) for no other reason than in a left crosswind I can only jam the cyclic into my left leg so hard before I run out of control movement. (Tall guy in an Astar problem) 1 Quote Link to comment Share on other sites More sharing options...
aeroscout Posted May 20, 2014 Report Share Posted May 20, 2014 There has been more than enough said by guys ahead of me about crosswind.I have had LTE twice and was able to recover both times.I have had full power pedal in on more than a few occasions.I was either lucky to have an escape route, or skilled by pre planning one.It helped me a lot to be able to weathervane into the wind and get back above ETL.My addition to the crosswind discussion is crosswind converting into tailwind.If in some of the above situations you keep the crosswind on your power pedal side, then you come to a hover, then turn your nose in the direction that would put your tail into the wind, be prepared for ETL backwards which can be an eye opener. 1 Quote Link to comment Share on other sites More sharing options...
vagabondpiper Posted May 20, 2014 Author Report Share Posted May 20, 2014 Welcome Vagabond! We love the PA-15! To answer your question: If I cannot land straight into the wind in an "American" helicopter (e.g. Bell), then I prefer a *LEFT* crosswind. I use the natural weathervaning tendency of the helicopter to minimize the amount of left pedal needed. I know that some pilots will vigorously argue this point. They think that if you land with a left crosswind then you WILL get into LTE. It's true because they read it in a book! I even had one guy complain about the Bell 206B with its "weak-ass" tail rotor because he landed one day when he was heavy with a *right* crosswind and nearly ran out of left pedal. Well...duh. I only have 11,000 hours of total time, mostly in Bell 206's, and I have NEVER gotten into LTE with a left crosswind... But what do I know?Sir thanks a lot for detailed reply , 11000 hours of experience cant be wrong . Quote Link to comment Share on other sites More sharing options...
vagabondpiper Posted May 20, 2014 Author Report Share Posted May 20, 2014 I agree. With a right crosswind, heavy, you run the risk of overtorquing if you have to put in a lot of left pedal. I've always preferred a left crosswind, and I only have a couple thousand hours more than Bob, but I've never seen LTE. Keep it slow, keep the rate of descent low, and you won't see it either. Cowboy it in, with a high rate of descent, hot, and you may see all sorts of bad things at the bottom. The 206 doesn't have a lot of TR margin to spare, but if you're smooth and careful you won't need any margin. I still have this discussion with check pilots, most of whom don't have enough experience to know what LTE really is, or what causes it. They've read the books, and answered the questions, but they don't really know how the aircraft reacts in many situations. I've had a few lately who had grey hair, but were still searching for a clue. Don't let the nose turn in the first place, and you can't get LTE. And it's easier to keep it from turning with the wind on the left. MI-17, I have no idea. Never been close to one. But the principle should be the same. Pusher or puller makes no difference, ETL makes no difference. Keep the crosswind where it takes less power to keep the nose straight. That's my opinion, and I haven't changed it in 40+ years.Thanks for such an elaborate reply sir Quote Link to comment Share on other sites More sharing options...
vagabondpiper Posted May 20, 2014 Author Report Share Posted May 20, 2014 I always prefer a right crosswind (In an Astar) for no other reason than in a left crosswind I can only jam the cyclic into my left leg so hard before I run out of control movement. (Tall guy in an Astar problem)Astar is French machine and French machines have right paddle as power paddle , correct me if i am wrong . Quote Link to comment Share on other sites More sharing options...
Azhigher Posted May 20, 2014 Report Share Posted May 20, 2014 Astar is French machine and French machines have right paddle as power paddle , correct me if i am wrong .True, but it's more of an ergonomic problem than a power or LTE problem. Quote Link to comment Share on other sites More sharing options...
Nearly Retired Posted May 20, 2014 Report Share Posted May 20, 2014 vagabondpiper says: Sir thanks a lot for detailed reply , 11000 hours of experience cant be wrong . Want to bet? *NO* pilot is so good that he cannot be wrong. *NO* pilot has so much experience that he never makes mistakes. Don't even think that 11,000 hours of experience can't be wrong. I absolutely CAN be wrong. I may not prove it to myself on a daily basis, but I do so fairly regularly. But here's what I *think*: LTE is an excuse that weak pilots use for crashing (or nearly crashing) a perfectly good helicopter due to bad technique on their part. Bell has done a lot of flight testing of the 206 over the years. The tail rotors of these aircraft do not spontaneously stop working or suddenly become ineffective. Quote Link to comment Share on other sites More sharing options...
Astro Posted May 20, 2014 Report Share Posted May 20, 2014 I'm a little confused here. When I'm coming in and suddenly the tail gets a bit squirrelly and I look over at the wind sock to see a left crosswind, that's not LTE? Quote Link to comment Share on other sites More sharing options...
Nearly Retired Posted May 20, 2014 Report Share Posted May 20, 2014 No. 1 Quote Link to comment Share on other sites More sharing options...
Jaybee Posted May 22, 2014 Report Share Posted May 22, 2014 I'm a little confused here. When I'm coming in and suddenly the tail gets a bit squirrelly and I look over at the wind sock to see a left crosswind, that's not LTE? from AC 90-95 LTE is a critical; low-speed aerodynamic flight characteristic which can result in an uncommanded rapid yaw rate which does not subside of its own accord and, if not corrected, can result in the loss of aircraft control. You corrected it so - no, as NR said. The 'and' in the sentence means that all three things must happen to have it - uncommanded yaw, does not subside, loss of aircraft control. Quote Link to comment Share on other sites More sharing options...
Wally Posted May 22, 2014 Report Share Posted May 22, 2014 I'm a little confused here. When I'm coming in and suddenly the tail gets a bit squirrelly and I look over at the wind sock to see a left crosswind, that's not LTE? That's not LTE anymore than the jiggle you get driving over a highway expansion strip is a loss of control skid.The TR in most helos located where a lot of changes happen quickly- main rotor wash and associated turbulence, ground effect, and the vertical stab. I attribute most of those small quick yaw variations to those effects. It could develop into LTE... I'm not as comfortable as some in saying that 206 LTE is ultimately poor pilot technique. The plan that allows adequate reaction requires that you prepare for it. The 206 TR is relatively weak and I've been on the left pedal stop on occasion. Quote Link to comment Share on other sites More sharing options...
Astro Posted May 22, 2014 Report Share Posted May 22, 2014 So its not considered LTE until after my feet fail to respond properly and I lose control? Quote Link to comment Share on other sites More sharing options...
cburg Posted May 22, 2014 Report Share Posted May 22, 2014 There's a saying "lose it to the right..goodnight". Quote Link to comment Share on other sites More sharing options...
cburg Posted May 22, 2014 Report Share Posted May 22, 2014 LTE AC Excerpt: 5. UNDERSTANDING LTE PHENOMENA. To understand LTE, the pilot must first understand thefunction of the anti-torque system.On U.S. manufactured single rotor helicopters,the main rotor rotates counterclockwise asviewed from above. The torque produced by themain rotor causest he fuselageo f the aircraft to rotatein the opposite direction (nose right). The anti-torquesystem provides thrust which counteracts this torqueand provides directional control while hovering. c. Tail rotor thrust is the result of the applicationof anti-torque pedal by the pilot. If the tail rotorgenerates more thrust than is required to counter themain rotor torque, the helicopter will yaw or turnto the left about the vertical axis. If less tail rotorthrust is generated, the helicopter will yaw or turnto the right. By varying the thrust generated by thetail rotor, the pilot controls the heading when hovering. d. In a no-wind condition, for a given main rotortorque setting, there is an exact amount of tail rotorthrust required to prevent the helicopter from yawingeither left or right. This is known as tail rotor trimthrust. In order to maintain a constant heading whilehovering, the pilot should maintain tail rotor thrustequal to trim thrust. e. The environment in which helicopters jly,however, is not controlled. Helicopters are subjectedto constantly changing wind direction and velocity.The required tail rotor thrust in actual flight is modifiedby the effects of the wind. If an uncommandedright yaw occurs in flight, it may be because thewind reduced the tail rotor effective thrust. e. The wind can also add to the anti-torque systemthrust. In this case, the helicopter will react withan uncommanded left yaw. The wind can and willcause anti-torque system thrust variations to occur.Certain relative wind directions are more likely tocause tail rotor thrust variations than others. Theserelative wind directions or regions form an LTEconducive environment. 6. CONDITIONS UNDER WHICH LTE MAY OCCUR. a Any maneuver which requires the pilot tooperate in a high-power, low-airspeed environmentwith a left crosswind or tailwind creates an environmentwhere unanticipated right yaw may occur. b. There is greater susceptibility for LTE inright turns. This is especially true during flight atlow airspeed since the pilot may not be able to stoprotation. The helicopter will attempt to yaw to theright. Correct and timely pilot response to anuncommanded right yaw is critical. The yaw is usuallycorrectable if additional left pedal is appliedimmediately. If the response is incorrect or slow,the yaw rate may rapidly increase to a point whererecovery is not possible. c. Computer simulation has shown that if thepilot delays in reversing the pedal control positionwhen proceeding from a left crosswind situation(where a lot of right pedal is required due to thesideslip) to downwind, control would be lost, andthe aircraft would rotate more than 360’ before stopping.d. The pilot must anticipate these variations,concentrate on flying the aircraft, and not allow ayaw rate to build. Caution should be exercised whenexecuting right turns under conditions conducive to the aircraft would rotate more than 360’ before stopping OTHER FACTORS. The following factors cansignificantly influence the severity of the onset ofLTE. a. Gross Weight and Density Altitude. Anincrease in either of these factors will decrease thepower margin between the maximum power availableand the power required to hover. The pilotshould conduct low-level, low-airspeed maneuverswith minimum weight. b. Low Indicated Airspeed. At airspeeds belowtranslational lift, the tail rotor is required to producenearly 100 percent of the directional control. If therequired amount of tail rotor thrust is not availablefor any reason, the aircraft will yaw to the right. c. Power Droop. A rapid power application maycause a transient power droop to occur. Any decreasein main rotor rpm will cause a correspondingdecreasein tail rotor thrust. The pilot must anticipatethis and apply additional left pedal to counter themain rotor torque. All power demands should bemade as smoothly as possible to minimize the effectof the power droop 1 Quote Link to comment Share on other sites More sharing options...
