Does the faa test for Marijuana on the class 3 medical certification?
  • Cpatterson changed the title to 3rd class medical test for Marijuana?
  • 2 years later...
From what I’ve seen, the FAA doesn’t include a drug test for marijuana in the 3rd class medical exam itself.
  • 1 year later...
I went the safe route and only used cbd isolate bulk before my test since it's pure CBD with no THC. Even trace THC from full-spectrum stuff can show up on a urinalysis, and that's not a fun conversation with the AME. I sourced mine from a reputable place with solid COAs just to be sure.
  • 1 month later...
There's an easy fix, STOP USING CBD.
I'm sure an OTC NSAID will work the same way CBD is doing for you
  • 5 weeks later...
DON'T EVEN ATTEMPT TO LIE ON THE FAA AIRMEN'S MEDICAL FORM 8500-8
As a FAA Licensed Pilot, including Student Pilots you are required to obtain an FAA Airmen's Medical Exam.  Aviation Medical Examiners (AMEs) are licensed medical doctors who have received additional certification from the Federal Aviation Administration (FAA) to conduct aviation medical examinations for pilots and complete FAA Form 8500-8.  IF YOU ARE CAUGHT FALSIFYING THIS FORM, (meaning lying or making a False Statement) YOU WILL BE PROSECUTED FOR A FEDERAL FELONY.
Recommendation:   What you you want out of life?
1) Continue Using an Illegal  Substance, that WILL cause adverse health effects? or;
2) Obtaining a FAA Pilot's License and enjoying the ability of manned flight
FAA Form 8500-8
Section 18 MEDICAL HISTORY
HAVE YOU EVER IN YOUR LIFE BEEN DIAGNOSED WITH,HAD,OR DO YOU PRESENTLY HAVE ANY OF THE FOLLOWING? Answer“yes”or“no”for every condition listed below.
In the EXPLANATIONS box below,you may note ‘PREVIOUSLY REPORTED,NO CHANGE”only if the explanation of the condition was reported on a previous application for an airman medical certificate and there has been no change in your condition.
Question #18m
Substance dependence or failed a drug test ever;or substance abuse or use
of illegal substance in the last 2 years.  Answer: YES   NO
Under Federal Law Marijuana, including all THC products are considered Illegal Substances.  Residing in a State where Marijuana is legal DOES NOT absolve you of this Federal Law.
