helidoc Posted February 10, 2005 Report Share Posted February 10, 2005 Anybody made the conversion to the elastomeric dampers yet and has it been worth it? Quote Link to comment Share on other sites More sharing options...
birddog Posted March 11, 2005 Report Share Posted March 11, 2005 helidoc, can you make the conversion on an "A" model? Quote Link to comment Share on other sites More sharing options...
helidoc Posted March 12, 2005 Author Report Share Posted March 12, 2005 Theoretically I guess you could since the rotor heads are the same for the most part. Unfortunatly, I think is presently is only for the 480 models with the right transmission. For example, I have a 1998 480 model and in order to mount the dampers I have to have the transmission take out so they can modify to the larger diameter main rotor mast. In other words, your transmission and mast have to be up to the newer 480B specs. Hopefully they will work on getting the piston models certified in the future as people tell me the new dampers are like a dream come true in getting rid of the Enstrom shuffle on start up and fly smoother too. It is just a little expensive now. Quote Link to comment Share on other sites More sharing options...
pairoboots Posted March 28, 2005 Report Share Posted March 28, 2005 I hear from the factory that they are testing the elastomeric dampers for certification on the piston models nowHopefully they will be available soon .pairoboots Quote Link to comment Share on other sites More sharing options...
