EC9xxx Posted July 16, 2005 Posted July 16, 2005 There are a few problems with the MEGHAS avionics system ("avionique nouvelle" glass cockpit on ECs 135/145). On some aircrafts, two strange behaviours were found : 1- Unexpected changes from Bcor mode to STD-mode, sometimes with a real altitude indication change. 2- Vertical speed discrepancy (hundreds of feet usually) between PFD1 and PFD2 on DPIFR aircrafts, most of the time at slow speeds (below 30 KIAS) but this happened two times at higher speeds (60 and 100 KIAS). Did some of you witness such strange behaviours on ECs ? Quote
