407 mast failure
rotormatic
 Share
INFORMATION LETTER 407-03-68
TO: All Owners/Operators of Bell 407 series Helicopters
SUBJECT: BELL 407 MAST – INCIDENT REPORT
This Information Letter is issued to advise of an unusual incident and to stress
the importance of adhering to the published Bell 407 maintenance procedures.
On 9 January 2003, a Bell 407 was flying in the Gulf of Mexico when the pilot
heard a noise, detected a vibration, and returned to his base for an investigation.
Visual inspection found a crack indication in the mast pole below the swashplate
drive hub and above the swashplate boot.
The crack extended circumferentially around approximately 40% of the mast outer diameter.
This is the first reported occurrence of this nature since Bell 407 deliveries began in January 1996.
While the cause of the crack has not yet been determined, preliminary
investigation reveals that the mast pole had been painted in the cracked area
and that corrosion was also visible. In view of the above the following points are
stressed:
· As noted in the CR&O manual the mast pole is not to be painted in that
area;
· Routine inspection is necessary to detect and remedy any sign of
corrosion during daily checks and scheduled inspections.
The Bell 407 comprises approximately 545 aircraft and has accumulated close to
800,000 flight hours. Bell Helicopter has given this investigation the highest
priority and operators will be informed of the results and further action if any, as
soon as possible.
 Share
