desertsoldier22 Posted June 23, 2006 Report Share Posted June 23, 2006 I am working on a UH-60L, and it throws a code relating to a faulty alternator stator. After removing stator I find oil in the stator and the alternator rotor pad. My question is...is there supossed to be oil in that area or do I have a bad D-axis seal? My tech manuals will not specify this fault in its inspection criteria. Quote Link to comment Share on other sites More sharing options...
67november Posted June 23, 2006 Report Share Posted June 23, 2006 i would highly suspect a bad seal, it should be dry on the inside. not familer with the particular unit. Quote Link to comment Share on other sites More sharing options...
