With so many versions of the S-76 out there I was wondering what the advantages and disadvantages of each are.
Heli Ops
  • 1 month later...
Wow! 2 months and not a bite... not many Tchaikovsky users out there?
We operate an S76-B.
Good things are: Heaps of power with PT6, 1033 HP per side
Fadec - removes those finger problems and looks after hot starts, looks after torque matching or T5 matching.
Dual digital autopilots - flies it better than I can, except in turbulence.
UNS-1 FMS , looks after navigation for me. Plus 2 more GPS for extra info
Extras like air con, extra soundproofing, ANR headsets (Sennheiser or Alzheimer or something - I can't remember...)
Glass screens for AI and HSI
Sat phone
Bad things are: No more room on the panel for any more toys
Engines suck the fuel @700 lb/hr
Endurance is only 2 hr 20 min to dry tanks
CG is a long way back.
By comparison, the A+ I learned on is a dog, steam-driven gauges, clockwork panel, spend all bluddy day twiddling the beep switches trying to match torques, sadly lacking in grunt. :(
Eric
Is that S76 the privately owned Hunter Valley located machine.
Heli Ops
Why do you ask, Two Dogs?
Isn't this forum anonymous?
Eric
Forum is. Just curious thats all.
By the way how is NR doing after his op.
Heli Ops
  • 1 month later...
"By the way how is NR doing after his op."
NR always operates at 107%.
I love trick questions. :P
Or perhaps you are located out of Townsville?  come on....fess up ???
Well, if "Out of Townsville" means "Not in Townsville", then you've got me narrowed down to 99.998% of the rest of Australia - geez, you guys are good! I'd better not answer any more questions because you are getting too close.
  • 3 weeks later...
I just finally found this forum, don't know why it has been hiding from me.   :cool:
The good things about the S76A:  well, it's faster than a Bell.
However, the engines are seriously lacking in power & reliability.
S76A++:  Not much bad I can think of.  The torques do move around, but even if they split there's still plenty of power.  With the A++, we just pull pitch & go, even a max gross in the summer.  Much of the time, the first limit is Vne.  We finally have something that can haul good loads way offshore to the deep water.  600lb/hr on the fuel if you're in a hurry, & a plannable speed of 140kts.  All our A models are being converted to A++, & should be finished this spring.  We have one C+ with the digital gauges, & it's very nice, but very expensive.  Hard to sell because of the cost, which is higher than a 214ST.
