blades & paint
500E
southernweyr
Us also, the Imron lasted about 15\20 hours on leading edge with the 500s blade speed the paint comes off real quick even with the max amount of blade tape, at least we don't have to worry about the blades pealing due to lack of paint, someone suggested the paint used on plastic auto parts like spoilers that is flexible
first a wash primer (on metal blades)
then an epoxy primer
then 2 coats epoxy enamel finish (flat) no gloss except tip stripe on upper surface
then I use a touch up gun at every 25 hour inspection and dress the outer +/- 5 feet.... (very light)
The touch up has never created a problem with track/balance.
I'm not a big believer in any name brand... i've used them all with equal success.
