harry250 Posted May 9, 2015 Report Share Posted May 9, 2015 helloI thought id ask this question here as this would be the best place to provide an accurate answer In the free to use web based flight simulatorhttp://www.gefs-online.com/gefs.php ( needs free google earth installed and runs fine from opra or firefox when brousers if you wanna give it a try ? )there is a model of a huges 300 helicopterthat really hard to fly !! I have a question about what happens when you want to turn the helicopter really fast from 40kts forward flight and get it flying in the oposite directionusing a 180 degree pirouette turn manouver(sort of manourer you might see done by a helicopter display team)This is what happen in the simFrom straight and level forward flight at 40kts say 100 ft aglkick in some right rudderhelicopter starts to yaw to the right but then the nose starts to pitch up automatically requiring pushing cyclic forward and right abitawell as the collective needs to be reduced abit ?? during this turn manouver so as to keep the nose aimed at the ground thought out the turn at an angle of 45 degrees approximatlythen as soon as you reached 180 degrees turnedcyclic back to pull nose up and increase collective to go back into into forward flight again ( only this time in the oppsite direction )what do you need to do in a real helicopter to achieve the same 180 pirouette degree manouver from 40kts forward flight??if you could decribe what needs to be done with the controls i would be greaftul as then i could compare to the simif the sims wrong i will not fly it any more as this could cause bad practicethanksreally looking forward to you replyharry 2 Quote Link to comment Share on other sites More sharing options...
PondJumper Posted May 18, 2015 Report Share Posted May 18, 2015 Completely misunderstood your question. Sorry Quote Link to comment Share on other sites More sharing options...
Azhigher Posted May 18, 2015 Report Share Posted May 18, 2015 Pirouette - From 40kts fowrward slam aft cyclic and crank the nose straight up into the air. As airspeed decreases karate kick the power pedal until the nose is pointing at the ground then point the cyclic forward to the spot you want to crash into. Done. Quote Link to comment Share on other sites More sharing options...
