Can anyone please shed some light on the Air Methods
interview process and the best way to prepare? Any advice from someone who has gone through the experience would be much appreciated!
Basic airspace weather mins.
Question: If the patient is dying, your med crew is yelling at you to get to a hospital but you think weather might be bad, do you continue?"
Answer: No.
Question: If the weather looks good but your crew is uncomfortable with (whatever) do you go?
Answer: No.
Question: Have you ever exceeded a limit, or damaged an aircraft? (reported or not)
Question: Have you ever been asked to compromise your integrity?
Question: Is a hot dog a sandwich? (Ok, you caught me, they didn't ask this)
When I interviewed they said since it was a union job they had a standard interview that they had to do with every applicant, so the interview was catered to the lowest common denominator.
All they expect you to do is be a safe, honest, competent pilot. They'll teach you the EMS stuff, the part 135 stuff etc... Honestly if you're being interviewed for a base it's probably your job to lose, so don't sweat it.
Good luck, Yossarian. (That's a catch-22 reference, in case you missed it)
Wow, thank you so much for your insight. And of course I got the Yossarian reference! Is there a flight portion of the interview process or is it all verbal?
There could be a flight portion but they didn't fly me. I was working at a company flying 130's and had a couple thousand hours between 130's and 350's so I guess they assumed I'd be ok. Another EMS company flew me after the interview and the flight was a normal and steep approach, no radio calls/navigation/anything.
And I pointed out the C-22 reference in case any dunces roll through here :ph34r: Can't count on everyone on the forum being such wise and well read individuals such as you and I. ;)
  • 1 month later...
Excellent. Thank you.
I also have an upcoming interview with AMC, did you have yours yet? If so, any additional info/suggestions?
Edited by Joe85sti
  • 4 years later...
My Air Methods job interview consisted of me in a room sitting at the head of a long table with 20 other people.  They all took turns around the table asking me questions.  Each time I tried to lighten the mood and heaviness in the room, they kept it very serious.  Probably the worst interview experience I've ever had.  But I'm sure each location does things a little differently.
