cinesoundasia Posted April 27, 2010 Report Posted April 27, 2010 Hey All, Need help wiring a NATO helicopter headset plug to a XLR cable to record sound from Helicopter radio. Any help much appreciated. P.S.. Since moving to Singapore,dont get to fly much...too much Singapore airspace restrictions...sigh... 1 Quote
500E Posted September 14, 2011 Report Posted September 14, 2011 Which NATO plug UK or US\Nexus\U174U Mil(TP120 commercial plug) PJ-068 GENERAL AVIATION MIC PLUGThis is the plug that's only used in aviation. The matingshaft of the plug is 5.23mm PJ-055 GENERAL AVIATION EARPHONE PLUGThe mating shaft of the plug is 6.35mm Mil:M642/4-1, NSN:5935-00-192-4760.You can buy a plug at any electronics store. U-174/U TP120 (TP-101) HELICOPTER HEADSET / HELMET PLUG This is a NEXUS plug, not a NATO plug(sometimes referred to as a US NATO plug)and it is not compatible with the UK NATOplug below. Wiring, Tip(1) Mic low (2) Ear high (3) Mic high (4) Ear low PLUG 671 UK or EUROPEAN NATO PLUG This plug will not mate with the Nexus range, themating shaft diameter is 0.43 mm bigger. This is aMil spec brass plug, NSN:5935-99-946-6652. Wiring,Tip Mic, Ring 1 Mic, Ring 2 Ear, Ring 3 Ear, (Ring 1next to tip) Mating Socket 626, NSN:5935-99-949-1940 Be carefull we bought 2 ANR kits, integrated power & audio leads, + ship power units from Headset services Amarillo, And specified UK NATO connectors they were supplied with TP120 plugs, when querying we were told they were the same, on pointing out the discrepancies they appeared to not know & said they could not send correct parts as they could not source. Go figure!!!!They offered to refund if we returned the goods to The US we are in the UK, & had fitted the wiring & units, this is not feasible so we will have to stand the hit, there were other problems as well. Quote
Signalsman Posted July 29, 2020 Report Posted July 29, 2020 I have an application with a desk mike that plugs into a radio transceiver using a UK NATO plug. I would like to know what the connections should be in this situation The wires I have are: mike high, mike low, PTT , ground. My concern is that if the set is on, then the unkeyed PTT line will be at 28 volts and I dont want that to connect to the mike insert when inserting or removing the plug. I'm thinking the PTT line needs to be on the tip so it is the last contact to be made when inserting and the first to be broken when removing the plug but there could be a proper standard for this application. Thanks in advance. Quote
500E Posted October 5, 2020 Report Posted October 5, 2020 Headset plug wiring.pdf Have come across different configurations though Quote
