Ok, this is really a VIDEO. One of my pilots has a new MacBook Pro, so I am finally able to use the footage from my GoPro HD camera. I hope this is better than my last attempt.
Hope you enjoy it!
Nice video John. Thanks for sharing it.
ironranger
Thanks! I'm working on an NVG mount for the GoPro right now. We have a spare set at the base. If I can get a mount together that doesn't interfer with anything else and still has a good view outside, I should be able to do some interesting shots.
Beautiful machine!
Great video too. Thanks for sharing.
Beautiful machine!
  • 5 months later...
One thought FWIW...
At 2:28, there is an Astar lifting. It comes off the ground and goes almost vertical immediately. My only thought (and I'm not criticizing) is something I learned something where I used to fly that I still use to this day that could be a life (or aircraft) saver. The 3 second hover/power check. When I come off the deck, I hold a hover for at least 3 seconds. Usually it's just enough time to check power avail, and P's and T's. An engine failure is more likely to happen at a major power change right? Well there isn't much more of a power change than when going from flat pitch on the ground to hover power and in that case, full TO power. I once saw an EC130 (same engine as that AS350B3) lift, hover for about 2 seconds and then shoot a 6 foot flame out of the exhaust...engine failed. Had there been no 3 second hover or a lift like that depicted in the video, it could have been a real issue but instead a simple hover auto from 3 feet and the AC was unharmed.
Like I said, just FWIW but I have seen it become of value and it doesn't cost a thing.
Cool videos though! :)
One thought FWIW...
Sebastian,
Are you talking about the shot with 2 birds on the pad?
Yup.
Hum...wasn't me flying it and guess I never really looked at it that closely.
But I do agree a quick look at your available power before going vertical (every takeoff out here requires vertical...some over 150').
Nice video. One problem though, the music you chose had me waiting for Pamela Anderson to come running up to the heli in a red one piece... A little dissapointed when it ended and that scene had apparently got cut from the final production. :D
My bad. I'll do a better job of editing next time!
