fstbk272 Posted December 19, 2016 Posted December 19, 2016 So I have a set of brand new h10-76's, and I want to use them in civilian helicopters. I know they will work by changing out the Mic to an Electret mic.... question is, is the 1142-22 Electret mic the only one that will work? Or can I use other model electret mics? Thanks - Roger Quote
iChris Posted December 21, 2016 Posted December 21, 2016 (edited) So I have a set of brand new h10-76's, and I want to use them in civilian helicopters. I know they will work by changing out the Mic to an Electret mic.... question is, is the 1142-22 Electret mic the only one that will work? Or can I use other model electret mics? Thanks - Roger The 1142-22 is a generic high-impedance electret microphone. It’s a direct replacement for the David Clark M-7/DC or Pilot Communications USA’s PA-5X., both of which can be used on metal/wire boom type headsets like the H10-76. Basically, you’re look for a high-impedance amplified electret microphone that can be mounted to the end of a metal wire type boom. You could also use your H10-76 as is (with its current mic) with the aid of a low-to-high impedance converter cable/adapter, cost $50 - $90. Pilotmill.com had one for $53, about the same price as a replacement mic. That's a second option were the H10-76 remains intact. Edited December 21, 2016 by iChris 1 Quote
fstbk272 Posted December 27, 2016 Author Posted December 27, 2016 The 1142-22 is a generic high-impedance electret microphone. It’s a direct replacement for the David Clark M-7/DC or Pilot Communications USA’s PA-5X., both of which can be used on metal/wire boom type headsets like the H10-76. Basically, you’re look for a high-impedance amplified electret microphone that can be mounted to the end of a metal wire type boom. You could also use your H10-76 as is (with its current mic) with the aid of a low-to-high impedance converter cable/adapter, cost $50 - $90. Pilotmill.com had one for $53, about the same price as a replacement mic. That's a second option were the H10-76 remains intact. Thanks! I saw the adapters also. I wanna go with the mic option just to keep outside clutter down. Just wanted to know if I was only restricted to that one replacement mic or not, as I don't particularly like the way it looks. ha. Thanks for the info. - Roger Quote
r22butters Posted December 27, 2016 Posted December 27, 2016 If its brand new perhaps you could exchange it for the H10-66 (my old headset) it has a built in high/low mic switch? Quote
Guest pokey Posted December 28, 2016 Posted December 28, 2016 this post reminds me of my 1st learning to fly (fixed wing 1st), cessna 150 with speaker from a 1940's radio, and hand held mic. ANYTHING is better than that. Quote
