Gabriel92 Posted February 14, 2020 Posted February 14, 2020 Greetings to the Experts in this forum, I am a new learning student wish to know what is meaning of Helicopter Down Wash Procedure, any example of the procedure would be appreciated. Thank you! Quote
Eric Hunt Posted February 15, 2020 Posted February 15, 2020 Down wash Procedure?? Get hose, wet aircraft, use soapy water, wash down. Simples. As far as a procedure to minimise downwash on approach or departure- it depends on your weight, how much clear area there is before and after your termination point, are there light fixed wing on the ground in the vicinity that you could tip over? Ten points and a Hershey bar if you can do it without anybody seeing. A slow approach with high power will give the most downwash. Quote
Gabriel92 Posted February 17, 2020 Author Posted February 17, 2020 Thank you for the answer, Do you have any idea on what are the impacts of the downwash force on a helideck with regards to safety? Quote
MDO Posted March 6, 2020 Posted March 6, 2020 You may be confusing terms. Rotor "downwash" on landing is just strong wind that will vary depending on the size and weight of the helicopter. You just need to be aware of who you may be blasting if they get too close to your landing spot. Obviously, you don't want to land on top of someone, and most people understand not to get too close to a landing helicopter. "Power settling" is a real danger, however. This is when you descend too vertical and too fast through your rotor downwash. The turbulence can disrupt airflow over the blades and affect your lift. That is why a little forward airspeed is necessary when approaching your landing spot. Quote
