johnmullinix Posted January 13, 2003 Report Share Posted January 13, 2003 JOHN B. MULLINIX II OBJECTIVE A Position in Aviation Maintenance SUMMARY Over 6 years experience in aircraft maintenanceOver 5 years experience in Aviation Ground Support EquipmentOver 3 years on Flight Status +850 hours EXPERIENCE Aircraft Management Maintained aircraft logbooks for current status and appropriate paper work. Helped in coordinating with scheduled and unscheduled maintenance. Ordered parts promptly for faults against the aircraft. Helped coordinate for higher levels maintenance. Maintained UH-60 for flight at all times. Performed on the spot inspections on other aircraft. Monitored times on aircraft in flight to maintain a good flow of scheduled maintenance. Aircraft Maintenance Worked on UH-60 model aircraft for over 6 years. Performed scheduled and unscheduled maintenance in accordance with proper technical manuals. Diagnosed maintenance problems and performed necessary adjustments. Performed troubleshooting procedures IAW technical manuals for electrical wiring. Removed and installed subsystem assemblies i.e. engines, transmissions, gear boxes, and avionics. Worked on multiple phases with dyncorp civilian contract to U.S. Army. Fluent with special tools used in aviation to include maintenance cranes and hoist. Prepared aircraft for deployments on C-5. Performed all air crew member duties as necessary with no aviation mishaps. Aviation Ground Support Equipment Maintained AGSE in 507th Med. Co. and 78th Aviation for a total time of 5 years. Worked on all types of AGSE equipment that pertains to the UH-60 and UH-1 i.e. jacks, maintenance stands, tugs, tow bars, and agpu. My experience consists of changing out component pieces to the inspection of equipment to ensure proper working order. Scheduling and turning in equipment to higher command for inspections or maintenance that couldn’t be done at my level. Trained in maintaining all paperwork that pertains to AGSE equipment and current technical manuals. Education and Training High School graduate 1996 Alvin C. York Agricultural InstituteAdvanced Individual Training (AIT) UH-60 helicopter repairer August-November 1996Driver and maintainer 1 ¼ ton, 2 ½ ton, and 5 ton trucks Work History 2000 June-Present Mechanic 78th Aviation Camp Zama, Japan U.S. Army2001 April- May 2001 Mechanic Philippines Support BK 01 U.S. Army2000 September-October 2000 Flight Crewchief +850 hours U.S. Army2000 June-Present Worked on multiple phases with Dyncorp U.S. Army1997 July- May 2000 Maintenance Test Flight Crewchief U.S. Army1999 February-October 1999 Mechanic Prince Sultan Air Base Saudi Arabia U.S. ArmyJuly 1997-April 2000 AGSE Mechanic 507th Medevac U.S. Army27 December 1997- May 2000 Mechanic 507th Medevac Ft. Hood, TX. U.S. Army Link to comment Share on other sites More sharing options...
Guest Curt Notter Posted January 24, 2003 Report Share Posted January 24, 2003 John, Type me a message at curt.notter@dossaviationjapan.com Let's talk. Link to comment Share on other sites More sharing options...
