Can one of you enlighten me as to the specifics associated with this? Is this like a type certificated item like a Factory Float Kit on a Cessna? If a ship doesn't have provisions, can you add them with an STC or something? If you have provisions is all you need to do is plug in the power and hook the line up? Do provisions include mirrors and bubble windows, or are those just add ons for convenience and safety? Thanks, Chris
Cargo hook provisions Bell kit p/n 206-706-335-005 are hard points on belly , two at forward rear seat
station and one center aft cross tube tunnel. Tee handle for manual release lower right of collective
and electrical toggle switch at base of cyclic grip with c/b in overhead panel for power. ref Bell SI-206-94
for installation. Cargo hook kit is a frame and hook assembly Bell kit p/n 206-706-335-101
and is an approved Bell Kit .If provisions installed already just hook up and log entries and wt+bal info .
Mirrors and bubble windows are aftermarket kits with STC's, and are needed,especialy the mirror.
Mike
