rev Posted February 2, 2003 Report Share Posted February 2, 2003 What's the best way to remove the Huck bolts or Jo Bolts in the push pull tubes under the floor? Has anybody used a drill guide like in Brown Tools? Do you need a metric bit? Quote Link to comment Share on other sites More sharing options...
shaboogamoo bob Posted February 17, 2003 Report Share Posted February 17, 2003 I have done a couple of these repairs and the method that worked good for me was to use a dremal tool with a fiber cutoff wheel. Wrap the tubing around the jo bolts with stainless steel blade tape for protection. Reassemble with the alternate bolts mentioned in the work cards. This allows easy access in the future. When cutting these all you are doing is to cut the collar off and then the bolt can be driven out. Hope this helps. Shaboo Quote Link to comment Share on other sites More sharing options...
rev Posted February 28, 2003 Author Report Share Posted February 28, 2003 Thanks Bob. The dremel worked OK. I knew drilling like the MSR suggested wasn't going to work. I can't believe theyused jo bolts there. We've got a 1999 B2 with 1500 hrsand so far its been very reliable. Easy to work on that's forsure. Quote Link to comment Share on other sites More sharing options...
