I grew up in the shadow of ERA 212s in Nikiski. There are times I miss home, but looking at those photos I realize there are plenty of times I don't :D
The heat worked fine. It's getting out and putting fuel in that's a pain
Here's one of the thermometer in my car on the way to work one morning.
5 more degrees lower and THAT would really be F'ing cold :o
I'm cold just looking @ that...while I study in my warm California home ! :)
edit: I'm not completely sure why my title is CFi poster :S..... far from that :o
Edited by Tawler
that is your post ranking, the more you post the higher your ranking. look at others and you'll see what I'm talking about.
What type of special precautions, limitations are there when you are flying when it is so cold? I assume everything gets parked in a heated hangar. Do you have time limits on how long you can shut down outside when you stop, or do you keep the engine running all the time? What about icing? Any problems with metal fatigue due to the extreme cold? Any info would be appreciated. Thanks!
