Had a question that crossed my mind a while back but I never got an answer for it. Our instrument training ship had a WAAS capable garmin 430 in it. I read somewhere to file G on your flight plan your GPS needed oceanic approach capability, of course I don't think we had those approaches loaded on there cause we are not over the ocean so I filled R for RNAV. Would you had filled G or R?
"G" only for you. I don't know what the oceanic thing is but with any approved (enroute or approach approved) GPS you would file G.. the waas wouldn't make a difference for filing... only your ability to legally fly an approach to particular minimums.
The confusion comes because we call GPS approaches GPS/RNAV approaches...
RNAV is usually terming LORAN equipment (an old ground based system similar to gps but not as good) RNAV also applies to VOR/DME equipment that you can input vor data into a "computer" and create a waypoint that is not ON the vor station... again, similar to a ground based gps but not nearly as convient. Even if you filed RNAV you wouldn't use "R"...
"R" is reserved for: Required Navigational Performance. The aircraft meets the RNP type
prescribed for the route segment(s), route(s) and/or area concerned
RNAV equipment would be:
/Y LORAN, VOR/DME, or INS with no transponder
/C LORAN, VOR/DME, or INS with transponder (No Mode C)
/I LORAN, VOR/DME, or INS with transponder (Mode C)
GPS systems fall under "Advanced RNAV"
/E Flight Management System (FMS) with DME/DME and IRU position updating
/F Flight Management System (FMS) with DME/DME position updating
/G Global Navigation Satellite System (GNSS), including GPS or WAAS,
with enroute and terminal capability.
/R Required Navigational Performance. The aircraft meets the RNP type
prescribed for the route segment(s), route(s) and/or area concerned.
