coptermedic Posted July 17, 2009 Posted July 17, 2009 I have a clarification question & cannot find a clear answer on interpretation. I took my CFI checkride in an R22 and received the instructor endorcement from the DPE specified in SFAR73. At the time I didn't have the required hours in an R44, but do now. So do I need a separate endorement for the R44 as an instructor or not. Most I've spoken to say my endorement I already posses to instruct in Robinson's is universal because as the last paragraph reads in the SFAR73, it don't separate R22 from R44 and that I only needed to meet the hour requirement. Anyone know the real answer?Thanks Quote
Sparker Posted July 17, 2009 Posted July 17, 2009 The FAR doesn't differentiate the 22 from the 44, but as a student I got two different endorsements to train in each of them, they just did it as a safeguard I guess. Technically I don't think it is required, but if it isn't too difficult might as well get it... Quote
coptermedic Posted July 17, 2009 Author Posted July 17, 2009 Hey Sparker, thanks for the reply. I received endorcements in both the R22 & R44 as well and I have no problem doing a check flight in the R44, I just haven't received a call back from the local DPE of even the FAA on this question. Quote
raptor Posted July 18, 2009 Posted July 18, 2009 Just recently did my SFAR-73 checkout in the R44 with the local DPE.True, the SFAR technically makes no distinction between the two aircraft for teaching - however, flight reviews ARE specific to each aircraft. Also, since you need a minimum of hours in either aircraft in order to act as PIC (without a flight review every 12 calendar months), pretty sure that means you need an endorsement that makes the distinction between the two in order to teach. They also have different flight characteristics (i.e., max glide config., min. descent rate, cruise speed, flight control rigging, etc.). Let us know if you find out otherwise! Quote
coptermedic Posted July 19, 2009 Author Posted July 19, 2009 I will definately let you guys know. i'm very curious. Quote
choppedair Posted July 20, 2009 Posted July 20, 2009 Both of the primary DPE's that Hillsboro used were under the impression that you need an endorsement for each.One would charge (unless you were already doing an R44 check ride and asked ahead of time), and the other was free as long as you let him fly it a bit! Quote
TCHone Posted July 20, 2009 Posted July 20, 2009 Heres one for ya: Does the SFAR 73 instructor endorsement count as a proficiency check to satisfy a flight review? Quote
Darren Hughes Posted July 21, 2009 Posted July 21, 2009 Heres one for ya: Does the SFAR 73 instructor endorsement count as a proficiency check to satisfy a flight review? That one is very much open to interpretation. I've spoken to some DPEs & FSDOs that say no and others that say yes. It's all down to the area that you're flying in. I called my local FSDO(Allentown, PA) on that very question about 3 weeks ago, and the response I got was, "Yes, it does satisfy the Flight Review." Certain FSDOs in certain areas do things in certain ways, so I like to operate by the old saying "When in Rome, do as the Romans do". Quote
coptermedic Posted July 21, 2009 Author Posted July 21, 2009 (edited) Ok guys here is the official word: R22 and R44 is a separate endorcement for instructor's. If you read the Sfar carefully, it still doesn't spell it out in plain language but does hint at it being separate. As a matter of fact, if you order the SFAR 73 training packet from Robinson, they even include an example of both endorcements for CFI sign off. As far as the SFAR counting as a BFR, as long as you get the SFAR & the BFR endorcement signed in your log book, then the answer is YES. Edited July 21, 2009 by coptermedic Quote
slick1537 Posted July 23, 2009 Posted July 23, 2009 (edited) So what does this mean for someone who is checkedout to instruct in the r22 and now wants to instruct in the r44? What will you have to demonstrate to the DPE to get the instructor endorsement from him? Edited July 23, 2009 by slick1537 Quote
choppedair Posted July 24, 2009 Posted July 24, 2009 So what does this mean for someone who is checkedout to instruct in the r22 and now wants to instruct in the r44? What will you have to demonstrate to the DPE to get the instructor endorsement from him? Mainly just the SFAR stuff. Low RPM recovery, enhanced auto's, governor off, etc. Should be no big deal. Quote
BlackHwk27 Posted July 25, 2009 Posted July 25, 2009 (edited) You'll definitely do some in some Hydraulic off stuff, and probably talk/discuss some about fuel injection as opposed to the carb'ed 22. I just did an hour flight and an hour ground with a guy from the local FSDO to get my 44 instructor endorsement. He also counted it as a BFR. Edited July 25, 2009 by BlackHwk27 Quote
