Since I'm still asleep I'll be brief.
You can't walk when you wear it.
Jets? No. No jets.
Its huge.
Until I can fly like the Rocketeer, you shouldn't claim your jet pack is finally here, unless the jet pack in your fantasies was also the size of a deep freezer and needed landing gear.
its not even a jet pack per se, with it's 2 ducted fans its a thrust pack.
and like plato siad you cannot walk with it. so what good is it if you need to truck it to the launch site :o
I think it's cool as hell....advances in power plants will make it small enough to carry around....I remember mythbusters tried to make one, but couldn't get a small/powerful enough engine.
I think mythbuster's problem was improper fan/ducting design. That combined with a small engine and heavy building materials.
I think the coolest thing about it is that it is a part 103 ultralight. Very neat to see people building new types of ultralights.
jet pack? not really - more like a fan-pack
useless? yes - can't even bring a bag or a camera
dangerous? yep (I don't think that parachute will help much under 100ft AGL, or when the thing tips over on the ground)
Do I want one? YES!
200hp 2-stroke, and 250lbs all up weight sounds like they are already pushing it regarding engine weight and power. The only way to do better than that would be a turbine, like a RR300 or a C20.
200hp is enough to power a R44 with 4 people on board, so these small ducted fans can't be very efficient..
