John90290 Posted March 16, 2010 Posted March 16, 2010 I got my private in a 300CBI and am now in the process of learning to fly the R22. I am a bit confused about logging time. Book says that I cannot log PIC in the R22 until I have 50 hours or already have 200 hours of helicopter time? If this is correct, i am going to spend a lot of money before i can start logging PIC thus dragging out my commercial ticket. I would have stayed with 300CBI but non in the area. Any advice would be helpful. Thanks, John Quote
delorean Posted March 16, 2010 Posted March 16, 2010 No, it says you cannot act as PIC. But [in some cases] as long as you are the sole manipulator of the controls, then you can log it as PIC + Dual received. Depends on the FSDO really. Ours said you could log the time since you were rated for cat/class when the sole manipultor of the controls. Double check with your FSDO or DPE. It's been a long time since I've read SFAR 73, but 200 ttl heli and 50 R22 was to instruct, not to act as PIC. I thought it was 10 hrs dual in a R22 for a PIC endorsement. Quote
Inferno Posted March 16, 2010 Posted March 16, 2010 Ya, its 10 hours dual instruction in the 22 for the PIC endorsement so you can go off and be PIC. In the 44 you can credit 5 hours of 22 time towards the 10. Quote
John90290 Posted March 16, 2010 Author Posted March 16, 2010 Thanks for the info, I will run it by the local DPE. I think 10 is more like it as i've been sole controls 99% of the time save for some excellent guidance by my CFI. I must say I like that little R22, she skoots along real nice. Quote
Shaun Posted March 16, 2010 Posted March 16, 2010 Thanks for the info, I will run it by the local DPE. I think 10 is more like it as i've been sole controls 99% of the time save for some excellent guidance by my CFI. I must say I like that little R22, she skoots along real nice. The 10 hours are required to act as a PIC, as delorean stated. "(1) No person may act as pilot in command of a Robinson model R-22 unless that person: (ii) has had at least 10 hours dual instruction in the Robinson R-22 and has received an endorsement" You can log PIC right away, as far as I know. Don't forget you also need an R-22 specific flight review as well to act as PIC. http://rgl.faa.gov/Regulatory_and_Guidance...74?OpenDocument Quote
Goldy Posted March 16, 2010 Posted March 16, 2010 Thanks for the info, I will run it by the local DPE. I think 10 is more like it as i've been sole controls 99% of the time save for some excellent guidance by my CFI. I must say I like that little R22, she skoots along real nice. John- where are you flying? Quote
