Flying Pig Posted June 24, 2014 Posted June 24, 2014 CAMTS Requirement2,000 Total hours1,500 Total hours helicopter1,000 Total hours PIC Helicopters500 Total hours turbine helicopters100 Total hours in Unaided Night OperationsCommercial and Instrument Helicopter RatingsIve seen this two different ways. Some ads will say what this one says, 2000 total hours, 1500 helicopter. Then others will read CAMTS Req: 2000 helicopter. This one in particular is from a PHI ad. Which one is actually the CAMTS req? 2000 total time or 2000 helicopter? Quote
aeroscout Posted June 24, 2014 Posted June 24, 2014 It is being interpreted both ways. But more companies like AEL and AMC are interpreting it to be 2,000 hours total, of which 1,500 have to be rotary. PHI still continues to interpret it as 2,000 hours rotary in most cases. Quote
Velocity173 Posted June 25, 2014 Posted June 25, 2014 CAMTS requirement is 2,000 TT and 1,500 TT helo: 05.07.00 PILOT IN COMMAND QUALIFICATIONS 05.07.01 The pilot must possess at least a commercial rotorcraft-helicopter and instrument helicopter rating. 05.07.02The pilot must possess 2000 total flight hours with a minimum of 1500 helicopter flight hours prior to an assignment with a medical service with the following stipulations: 1. At least 1000 of those hours must be as PIC in rotorcraft 2. 100 hours unaided (if pilot is not assigned to an NVG base/aircraft) 3. 100 hours unaided or 50 hours unaided as long as the pilot has 100 hours aided (if assigned to an NVG base/aircraft) 4. A minimum of 500 hours of turbine time―1000 hours of turbine time strongly encouraged 05.07.03 ATP certificate and instrument currency is strongly encouraged Doesn't mean the employer won't require a higher min though. Ours exceeds CAMTS requirements. Quote
Flying Pig Posted June 25, 2014 Author Posted June 25, 2014 Ok thanks. Finally nice to see I am at the point where I read these ads and say "Hmmm... I could put in for that" 2 Quote
aeroscout Posted July 11, 2014 Posted July 11, 2014 Ok thanks. Finally nice to see I am at the point where I read these ads and say "Hmmm... I could put in for that" Go for it Flying Pig ! 1 Quote
