alexandrepvi Posted May 23, 2023 Report Share Posted May 23, 2023 Hello everybody, I would like to discuss performance class 2 operations as compared to CAT A / PC1 operations on the S92. If you are at MTOW (26.500lb), MSL, 1013, zero wind, 32°C, your TDP would be 47kt and you would be able to safe reject in 2.343ft (iFly precision) =) And for the same conditions you will have to limit your take off mass as temperature goes above 32°C. But if we use the chart for PC2: MAXIMUM TAKEOFF AND LANDING GROSS WEIGHT BASED ON 150 FPM OEI CLIMB AT 1000 FT ABOVE THE TAKEOFF SURFACE CT7−8A MAXIMUM CONTINUOUS OEI POWER BEST ROC SPEED We have a limitation that starts from 34°C. Does anyone knows the reason for this difference? If we are taking off from a paved clear runway shouldn´t those two be the same? Best regards, Vidual Quote Link to comment Share on other sites More sharing options...
helonorth Posted May 25, 2023 Report Share Posted May 25, 2023 Try pprune. This is mostly a US forum and not much cat A being done around here. Quote Link to comment Share on other sites More sharing options...
