Kelly N. Posted July 28, 2008 Posted July 28, 2008 Hi, I was trying to update my blog after several weeks (last time I updated it was well before the upgrade) and I cannot access the link. I get the following errors: Warning: chdir() [function.chdir]: No such file or directory (errno 2) in /home/helicopt/public_html/helicopterforum/blog/36lima/index.php on line 6 Warning: chdir() [function.chdir]: No such file or directory (errno 2) in /home/helicopt/public_html/helicopterforum/blog/36lima/index.php on line 6 Warning: chdir() [function.chdir]: No such file or directory (errno 2) in /home/helicopt/public_html/helicopterforum/blog/36lima/index.php on line 6 Warning: chdir() [function.chdir]: No such file or directory (errno 2) in /home/helicopt/public_html/helicopterforum/blog/36lima/index.php on line 6 I tried accessing another blog on the list and could get into it just fine. Is this a known issue? Any resolution? Thanks,Kelly Quote
PhotoFlyer Posted July 29, 2008 Posted July 29, 2008 (edited) It's known now. Thanks for the heads up. Probably will be a day or two for a fix to happen. Please be patient until then. Thanks! --PF Update: The following blogs are working (0430Z, 7/29/08). All the others do not work. There were too many names to type the ones not working. Gunner's blogWest Coaster's blog67november's blog500E's blog Edited July 29, 2008 by PhotoFlyer Quote
500E Posted July 29, 2008 Posted July 29, 2008 Mine seems to work as list but with a twist, posted 1 pic all OK posted second pic, text came up but no pic closed down site re entered and posted ok tried for another pic same result Quote
Kelly N. Posted July 29, 2008 Author Posted July 29, 2008 It's known now. Thanks for the heads up. Probably will be a day or two for a fix to happen. Please be patient until then. Thanks! --PF Update: The following blogs are working (0430Z, 7/29/08). All the others do not work. There were too many names to type the ones not working. Gunner's blogWest Coaster's blog67november's blog500E's blog VR Tower, Waiting patiently. Blogger 36lima. Quote
67november Posted July 30, 2008 Posted July 30, 2008 VR Tower, Waiting patiently. Blogger 36lima. :D Quote
PhotoFlyer Posted July 30, 2008 Posted July 30, 2008 VR Tower, Waiting patiently. Blogger 36lima. Well theres your problem... You didn't call clearance delivery first... :D :P Quote
Kelly N. Posted August 2, 2008 Author Posted August 2, 2008 Well theres your problem... You didn't call clearance delivery first... :D :P ha!! Quote
AdminLB Posted August 2, 2008 Posted August 2, 2008 Hi, I was trying to update my blog after several weeks (last time I updated it was well before the upgrade) and I cannot access the link. I get the following errors: Warning: chdir() [function.chdir]: No such file or directory (errno 2) in /home/helicopt/public_html/helicopterforum/blog/36lima/index.php on line 6 Warning: chdir() [function.chdir]: No such file or directory (errno 2) in /home/helicopt/public_html/helicopterforum/blog/36lima/index.php on line 6 Warning: chdir() [function.chdir]: No such file or directory (errno 2) in /home/helicopt/public_html/helicopterforum/blog/36lima/index.php on line 6 Warning: chdir() [function.chdir]: No such file or directory (errno 2) in /home/helicopt/public_html/helicopterforum/blog/36lima/index.php on line 6 I tried accessing another blog on the list and could get into it just fine. Is this a known issue? Any resolution? Thanks,Kelly Hi Kelly, About 8 days ago we move the VR Forum to a new host. We think we have hit most of the big stuff and now are looking for little bugs. Thanks for reporting that. I just put in a support ticket to Invision Power Board to take a look at that error. Thanks for reporting it to us!! Quote
AdminLB Posted August 3, 2008 Posted August 3, 2008 Blogs repaired........fire away! Thanks again for reporting the problem. Quote
Kelly N. Posted August 4, 2008 Author Posted August 4, 2008 Blogs repaired........fire away! Thanks again for reporting the problem. Works great now. Thanks! Kelly Quote
