slick1537 Posted June 8, 2009 Posted June 8, 2009 I am a little confused about the 10 hour rule for the 100 hours inspections and hoping someone could shed some light on it. To keep the numbers simple lets say your inspection is due at the 100 hour mark on the Hobbs. You fly 10 hours to a place where the inspection can be performed. Now the Hobbs says 110 hours. Is your next 100 hour inspection due at 200 hours on the Hobbs or 210 hours on the Hobbs? Quote
Hovergirl Posted June 8, 2009 Posted June 8, 2009 Your next inspection is due 100 hours after the last one was DUE -- i.e. at 200 hours. Quote
slick1537 Posted June 8, 2009 Author Posted June 8, 2009 That clears it up, thanks guys, and girls. Quote
Darren Hughes Posted June 9, 2009 Posted June 9, 2009 Hope you don't mind me adding my own little question in here. What about if you do your 100 hour inspection an hour early or even 0.1 hour earlier than it was due, say 300 hours on the hobbs. When is the next one due? Quote
BOATFIXERGUY Posted June 9, 2009 Posted June 9, 2009 Hope you don't mind me adding my own little question in here. What about if you do your 100 hour inspection an hour early or even 0.1 hour earlier than it was due, say 300 hours on the hobbs. When is the next one due? If you did it at 99.9, then it's due at 199.9 even though it wasn't schedule until 100 hours. You don't get any extra time except for the 10 hours which really isnt extra time between hours. That's just for getting it to a maintenance facility and can not be intentionally overflown for revenue. Quote
Gomer Pylot Posted June 9, 2009 Posted June 9, 2009 The next inspection is due 100 hours from the time the current one was completed, or due, whichever is earlier. That's the bottom line. Quote
slick1537 Posted June 12, 2009 Author Posted June 12, 2009 Does the 10 hour rule apply to annual inspections as well or only 100 hours inspections? Quote
BOATFIXERGUY Posted June 12, 2009 Posted June 12, 2009 There's no hour requirement on annuals unless you're doing a 100 hour/annual. A 100 hour only applies to commercial ops. Quote
kodoz Posted June 12, 2009 Posted June 12, 2009 Sure, you can fly it for 1 yr and 10 hours before the next annual. Just kidding. 91.409 will answer all ur questions. There is no exception provided for the annual, except that the inspection has to have been done within the previous 12 mos. I'm assuming that means that, for an aircraft to fly today, it must have had an annual sometime after May 31st, 2008. Quote
rotormandan Posted June 12, 2009 Posted June 12, 2009 Sure, you can fly it for 1 yr and 10 hours before the next annual. Just kidding. 91.409 will answer all ur questions. There is no exception provided for the annual, except that the inspection has to have been done within the previous 12 mos. I'm assuming that means that, for an aircraft to fly today, it must have had an annual sometime after May 31st, 2008. I would think that an annual would have to have been done at least on 6/12/08. Then today would be the last day. Or does the far say calender months? (no far w/me) Then we could keep flying till the end of the month until it's due if it was done on the 12th last year. Quote
slick1537 Posted June 12, 2009 Author Posted June 12, 2009 That was a horrible question, don't ask me what I was thinking, because I don't know. Quote
