Carb icing
Reason for not using carb heat below -10C
31 members have voted
1. Below -10C....
warming air coming into the carburetor with the carb heat makes it possible for water vapor to condense and freeze when it cools again in the throat.4
carb heat melts frozen water in the air, allowing it to refreeze in the throat.8
it doesn't really matter, since there's so little moisture in the air that the risk of carb ice is extremely low.17
whatever ice forms in the carburetor is dry and doesn't stick; using carb heat allows it to adhere.1
the difference is irrelevant, just memorize the rules for using carb heat.1
