tattooed Posted July 10, 2010 Posted July 10, 2010 I'm a lower time CFI, and I'm currently going thru my notes and lesson plans. This weekend I am going thru DA and PA notes. I just wanted to be able to document the various way one can calculate DA...other than the "whiz wheel" and digital e6b (no cheating with your iPhone!). Quote
tattooed Posted July 10, 2010 Author Posted July 10, 2010 (edited) See, a method! LOL! Great, now I am hearing that dude's voice in my head. Thanks. Like a bad song. 1. e6b/Flight Computer2. POH DA chart3. Call ASOS Edited July 10, 2010 by tattooed Quote
Trans Lift Posted July 11, 2010 Posted July 11, 2010 An iphone ain't cheating mate. Whatever makes life easy! Quote
Trans Lift Posted July 11, 2010 Posted July 11, 2010 (edited) It can be done mathematically too, as you probably know. For example, using the formula, we find the following:PA= HA + PAVPA = 1,500 + 1,000(29.92 - 29.41)PA = 1,500 + 510PA = 2,010 feet DA = density altitude, PA = pressure altitude at the level you desire density altitude, 120 = a temperature constant (120 feet per 1°C), andVt = actual temperature minus standard temperature at the level of the pressure altitude. For example, let's say the surface temperature is 30°C and your pressure altitude is 2,010 feet. find the standard temperature corresponding to 2,000 feet. You should find 11°C. Plug these values into the formula to find the following:DA = PA + (120 Vt)DA = 2,010 feet + [120(30°C - 11°C)]DA = 2,010 + 120(19)DA = 2,010 + 2,280DA = 4,290 feet I prefer an iphone or some sort of computer! Edited July 11, 2010 by Trans Lift Quote
ChprPlt Posted July 11, 2010 Posted July 11, 2010 Straight from my lesson plans: This is set up for the airport I trained at so just change your field elevation where needed. Computing Density altitude via equation – 1. Pressure Altitude- your standard pressure is 29.92”hg – subtract the current pressure from standard and then multiply by 1000, add positive numbers and subtract negative numbers from your field elevation. So if you had a pressure reading of 30.06 you would subtract 29.92 – 30.06 =-0.14 multiply this by 1000 = -140 so subtract 140 from 1382 = 1242’ PA The 1000 represents the lose of horse power, for every thousand feet of altitude. We loose 7 HP of engine performance. 2. Density Altitude – Pressure altitude corrected for non standard temperature. Standard temperature is 15C, First step will be to find our standard temperature for our elevation, 1382 @ IWAMultiply 1382 by. 002 = 2.764 now subtract this from the standard temperature of 15C12.236C is what our standard temperature is. Now you will need to figure out how much warmer it is than standard, so subtract our standard temp from current, lets say 35C = 22.764C above the ISA, This will effect the performance substantially, multiply your answer 22.764 by 120 = 2731.68 the 120 represents 120’ loose of helicopter performance for every 1C over the ISA. Now we take our pressure altitude and add to our temperature equation 1242 + 2731.68 = a Density altitude of 3973.68 feet. Easy right?? Quote
lelebebbel Posted July 11, 2010 Posted July 11, 2010 (edited) ... or, in simpler terms: 1) calculate your pressure altitude 2) find the ISA temperature for that pressure altitude (15ºC at sea level, ~2ºC less per 1,000ft AMSL) 3) Look at the ambient temperature. For every ºC warmer than the standard temperature, add 120ft to the PA to get the DA. If it is colder than standard, subtract 120ft per ºC. Edited July 11, 2010 by lelebebbel Quote
tattooed Posted July 11, 2010 Author Posted July 11, 2010 oh you people! I am trying to teach STUDENTS, no support AT&T. LOL.iPhone NOT allowed when you are my student. (guess what I use to calc DA....iPhone) At ChprPlt, Trans Lift, and lelebebbel (Hi D!!)THANK YOU!! That is exactly what I need. Quote
kodoz Posted July 11, 2010 Posted July 11, 2010 There's always the density altitude chart in the POH (p 5-3). Quote
tattooed Posted July 11, 2010 Author Posted July 11, 2010 There's always the density altitude chart in the POH (p 5-3). Already had that as "Option #2". Quote
Gomer Pylot Posted July 11, 2010 Posted July 11, 2010 I just tune up the ASOS/ATIS and listen to the last element of the weather. If I bother at all. I don't really care about the DA numbers, just whether not not the ship will fly, and if it will hover, it will fly. Quote
HeliJet Posted July 22, 2010 Posted July 22, 2010 I just tune up the ASOS/ATIS and listen to the last element of the weather. If I bother at all. I don't really care about the DA numbers, just whether not not the ship will fly, and if it will hover, it will fly. True, but..... It flew when you took off, but here in Colorado it is not unusual to have the temp increase by 3-10 degrees C during the course of a flight, especially if there is a brief shower with our high evaporative cooling. Another scenario: You took off out of KBJC at 10:00 AM and it was 30 deg. C., but you're landing in the mountains at 9200' msl and the helo's OAT says its 22 degrees C. What's your DA? Remember, your Pax will freak out if you let go of the controls and start rummaging through the POH.... Quote
Tom22 Posted July 22, 2010 Posted July 22, 2010 You could calculate DA from the equation of state using the standard atmosphere table. Quote
