Helios Posted October 21, 2012 Posted October 21, 2012 Just curious how many operators (if any) use infrared to look for electrical issues on substations and lines? Quote
iChris Posted October 22, 2012 Posted October 22, 2012 Most of the companies that specialize in power line work already provide that service. To name just a few: Air2 Haverfield Winco Summit Helicopters Idaho Helicopters Colorado Helicopters Chesapeake Bay Helicopters P.J. Helicopters http://pjhelicopters.com/2012/07/pge-pj-helicopters-infrared-project/ Quote
Helios Posted October 23, 2012 Author Posted October 23, 2012 Thanks for the reply. Yea I should have done a bit more research, I see most do this actually. I am gonna go look this up....but while I am here. For anyone that has actually used the infrared cameras used by one of these companies how accurate are the temperature measurements given for the problem areas? Or is it just a general (you have a problem here) type thing, without temperature measuring capability. Quote
iChris Posted October 23, 2012 Posted October 23, 2012 Thanks for the reply. Yea I should have done a bit more research, I see most do this actually. I am gonna go look this up....but while I am here. For anyone that has actually used the infrared cameras used by one of these companies how accurate are the temperature measurements given for the problem areas? Or is it just a general (you have a problem here) type thing, without temperature measuring capability. It depends on the system used. The FLIR Systems 2000 series infrared camera has a thermal resolution of 1/10°F, and a pictorial resolution of 525 lines per frame. Below is an example of what’s out there. http://youtu.be/uBaiRvyPRg8 Quote
Trans Lift Posted October 24, 2012 Posted October 24, 2012 I used a Thermal camera that was accurate down to the degree from 800ft. It is a military grade camera. Quote
achfly Posted October 25, 2012 Posted October 25, 2012 Normal black and white IR cameras that you find on helicopters (police and military mostly) don't have a clue what the temperature is. They produce a picture based on the difference in temp. from one object to another or one spot to another. those color coded pics indicating spcific temperatures are made by some other kind of high tech IR camera. Quote
Flying Pig Posted October 25, 2012 Posted October 25, 2012 FLIR makes those types of cameras. But in a military or LE environment there isnt a need to know the temperature so we dont buy them. Quote
LUDACHICK Posted May 10, 2013 Posted May 10, 2013 jumping in with a question on this topic. I have been given the opportunity to fly with a company using the FLIR Corona 350 system in an R44. I am a student pilot and experienced aerial photog. but Ive always used the basic DSLR, position the heli, lean out the window and the get the shot method. Ive played with the computer operated system but minimally. Im having a hard time finding formal training on this and would appreciate any and all advice / leads on how to learn this. Quote
LUDACHICK Posted May 10, 2013 Posted May 10, 2013 PS Im not looking to be the PIC just the camera operator. Ive gotten alot of info. on getting hours and training to actually fly the aircraft, Im hoping to get info on the actual camera operation. Thank you! Quote
500F Posted May 13, 2013 Posted May 13, 2013 I looked into buying a FLIR last year. FLIR offers trianing. You may have to go to their office in Wilsonville, OR. Or, I believe they can come to you as well. I was told training was included with the initial purchase, I'm not sure what kind of cost you would expect for training additional people after the fact. Quote
