Weads Posted April 23, 2017 Posted April 23, 2017 There are some brilliant people on here that I would like to ask a question. In a hover auto show r simulated stuck right power approach what makes us yaw left when we roll off throttle? Thanks so much! Quote
Astro Posted April 24, 2017 Posted April 24, 2017 35 people were just reading this, but no one responded, so I guess I'll take a whack at it. Even with a stuck right pedal the tail rotor is still producing anti-torque thrust (just not enough to keep the nose straight) so when you roll down the throttle main rotor torque is reduced, which in turn reduces the amount of anti-torque you need, so the nose yaws left. 1 Quote
iChris Posted April 26, 2017 Posted April 26, 2017 (edited) In a hover auto show r simulated stuck right power approach what makes us yaw left when we roll off throttle? Too much left pedal applied following the throttle chop or lack of right pedal, #1 common error. Moreover, just too much positive tail rotor pitch remaining vs. the level of torque. Power Failure in a Hover, Common Errors: 1. Failure to use sufficient proper anti-torque pedal when power is reduced. 2. Failure to stop all sideward or backward movement prior to touchdown. 3. Failure to apply up-collective pitch properly, resulting in a hard touchdown. 4. Failure to touch down in a level attitude. 5. Failure to roll the throttle completely to idle. 6. Failure to hover at a safe altitude for the helicopter type, atmospheric conditions, and the level of training/ proficiency of the pilot. 7. Failure to go around if not within limits and specified criteria for safe autorotation. REF: Helicopter Flying Handbook Page 11-7Chapter 11: Helicopter Emergencies and Hazards Edited April 26, 2017 by iChris Quote
Eric Hunt Posted April 28, 2017 Posted April 28, 2017 7. Failure to go around if not within limits and specified criteria for safe autorotation.Going round from a hovering engine failure, I like that! Quote
