copter doctor Posted February 22, 2007 Posted February 22, 2007 Just saw a link on PHPA website with pic. of the first ARH crashed on a golf course, not good for a program like that. Stated that it it lost power. Quote
Gunner Posted February 22, 2007 Posted February 22, 2007 http://www.chron.com/disp/story.mpl/metrop...an/4571311.html Quote
copter doctor Posted February 22, 2007 Author Posted February 22, 2007 Thanks for the link Gunner, That article said it was the fourth ARH. Provided a little more info. Quote
Linc Posted February 22, 2007 Posted February 22, 2007 New, untested engine...guess I'd better brush up on my autos. Quote
Linc Posted January 15, 2017 Posted January 15, 2017 NTSB Identification: DFW07CA06614 CFR Part 91: General AviationAccident occurred Wednesday, February 21, 2007 in Mansfield, TXProbable Cause Approval Date: 05/29/2007Aircraft: Bell ARH-70 Exp., registration: N445HRInjuries: 2 Uninjured.NTSB investigators used data provided by various entities, including, but not limited to, the Federal Aviation Administration and/or the operator and did not travel in support of this investigation to prepare this aircraft accident report.The helicopter rolled over during an autorotation following a loss of engine power. The commercial test pilot was performing required test card procedures on the maiden flight of the experimental helicopter. The pilot reported that when he initiated a test flight sequence that called for the helicopter to be configured for slow flight in a shallow descent, the engine low fuel pressure light illuminated followed by an audio alert indicating an engine flame-out. The pilot reported that he immediately entered an autorotation that required a 180-degree turn to the left in order to reach the best available landing area on the fairway of a local golf course. With the helicopter aligned with the intended landing area, the pilot noted that the selected flight path conflicted with a tree on the approach, so the pilot applied collective pitch to slow the rate of descent and clear the tree. As soon as the helicopter cleared the obstacle, the pilot again re-entered a full autorotation. The helicopter touched down in a near level attitude with a slightly faster than normal forward speed. The pilot reported that as the helicopter settled on the golf course fairway, the landing skids began to dig into the soft terrain. The aircraft rocked forward and the toes of the skids dug into the ground, which resulted in the landing gear assembly breaking-off the airframe at all four attachment points and the forward looking infrared mount assembly impacting the ground. The aircraft continued to pivot on the nose and came to rest on its left side, which resulted in structural damage. The investigation revealed that the fuel line to the engine was blocked at the fuel boost pump assembly where the check valve mounts to the fuel switch. Foreign objects were lodged in each of the two check valves, which created a fuel starvation situation and the subsequent engine flame-out.The National Transportation Safety Board determines the probable cause(s) of this accident as follows:Fuel starvation due to blockage in a fuel system check valve which was the result of the improper assembly of fuel boost pump by company maintenance personnel. https://www.ntsb.gov/_layouts/ntsb.aviation/brief.aspx?ev_id=20070328X00341&key=1 Closing the loop. 1 Quote
