Is RW that much more expensive than FW?
Let's assume 200TT for RW and 250TT for FW:
Are my calculations accurrate?
RW:
Total of 100-hours solo in an R-22 @ $210/hr = $21,000
25 hours dual in an r-22 @ 250/hr= $6,250
40 hours in a Schewizer 300 for instrument @ 300/hr $12,000
35 hours dual in r-22 for commercial/CFI @ 280/hr $9,800
Total: $49,050
Fixed-wing
125 hours solo in a C-172 at $120/hr $15,000
25hrs dual in C-172 @ $170/hr $4,250
40hrs instrument @ $170/hr $6,800
35hrs dual for commercial/CFI at $170/hr $5,950
25hours multi-engine at $300/hr $7,500
total: $39,500
Above assumes another $5,000 for misc. gear/books/fees, of course
It will probably cost you more than that for 200 RW hours. RW is more money than FW for sure. But, there is alot more excitement in flying a helicopter than there is in a airplane.
Have you flown these aircraft ?
Keith
Keith
I've been going back-and-forth between RW and FW; don't have much time in either though. For FW I was training on a Piper Warrior, but my school's sole Piper was retired and it was replaced by the cessna, which I haven't flown yet.
Edited by franknyc
Are you thinking of a career? If so if you start adding up multi engine costs then at the end it really isn't that much cheaper to go fixed wing though the potential to make more is there.
RW:
Total: $49,050
Fixed-wing
total: $39,500
Why does your FW CFI earn $10/hr more than your RW CFI?
Why can't you get your RW instrument rating in a R22?
Why does the H300 cost $50/hr more than the R22?
Why does dual "commercial" R22 time cost $30/hr more than regular dual R22 time?
Why does multi-engine time cost $300/hr?
Why do you need a 25 hours just to get a multi-engine rating?
Personally, I think you need to visit a flight school and get an accurate cost analysis. I think your prices are inconsistent and your times are unrealistic.
I think palmfish hit on a number of things I was also thinking. To add an item I think the instrument rating would be less because you can do 20 hours without the instructor on board. I would also recommend using a simulator as you can do so much more with them that you can't experience in the aircraft i.e. failed instruments, radios, or engine problems. It is all very good practice and is less expensive than an aircraft. I think a simulator is under used because everyone wants the PIC time which is valuable. Even if you don't do a lot of sim training I strongly recommend at least a few hours in the sim.
remember U half to have 300Hrs fixed wing to get comm CFI.
Rotor is 150hrs.
and when U start flying Complex for comm, Cost is way more.
I work in both FW & RW both are a freekin awesome.
JARED
Besides the hour issues brought up with FW already, I only pay $89 an hour for a 172 and $114 dual. That may be lower than the average hourly rate I dont know, but is a big difference from your calculation in the long haul.
Maybe it's the lack of sleep catching up with me, but why are you gonna fly 100 hours solo?
Fixed wing commercial only requires 250 hours and only 50 of those have to be in an airplane. The only time requirement I found for CFI is the 15 hours as PIC in cat & class. That is probably for glider CFI's since you can get a private and commercial glider with less than 5 hours flight time if your a 200+ hour fixwinger.
61.183 (j) Log at least 15 hours as pilot in command in the category and class of aircraft that is appropriate to the flight instructor rating sought; and
Jerry
