Is a 150xl the only GPS you have access to? I would highly recommend anything newer...
430/530. GTN etc..
We had those in our aircraft years ago...... fortunately we upgraded to the G530s!
It will be OK for situational awareness only while training for the RW instrument rating. However, you will not be able to use them for any type of GPS approaches. The Garmin 150XL is certified for VFR purposes only and therfore does not have the database capability of doing a GPS approach.
http://www8.garmin.c...ducts/gps150xl/
But, a picture is worth a thousand cross-checks and the little moving map will give you that!
